Question about HP iPAQ 612C Smartphone
Ipaq PDA completely dead.
Ipaq completely dead. Has locked up on various screens. After hard reboot freezes on screen alignment screen
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
Dead screen/touchpad
the touchscreen is most likely damaged, you can open the pda to see if the connectors are ok and so on but here is a replacement part for you
http://www.ipaqrepair.co.uk/view_product.php?product=540
Mar 25, 2008 | HP iPAQ HX2400 Pocket PC
Touch screen will not work
try to reboot it, there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Dec 12, 2007 | HP iPAQ RZ1710 Pocket PC
Frozen screen
hello :-) i just talked to another person who was having the same problem as you. And guess what?? the same problem happened to me on my IPAQ 4350. It turned out when I would hard reset my IPAQ it asked me to align the screen but it wouldn't move and it would freeze and not let me pass . But I later found out that my screen was damaged and I got a new touch screen installed and my IPAQ works perfect :-). I would recommend for you to do the same and call HP and see if they could install it for you. Thanks :-}
Nov 05, 2007 | HP iPAQ H2210 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
HP iPAQ 612C Smartphone Logo
219 people viewed this question
Top HP Cell Phones Experts
D. E. Hev
Andrew Taylor
Andrew Taylor
richie46
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
