Question about HP Office Equipment & Supplies
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
    Guru:
  • 830 Answers
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Posted on Sep 13, 2009
How do i print on photo supreme paper?
Not all printers can print on all photo paper stock. Check with HP and see if your printer can usethat paper. Sounds like it is too heavy/thick.
Feb 28, 2015 | HP LaserJet Office Equipment & Supplies
How do you remove paper tray on hp photosmart 8250 printer to clear paper jam
Hi we2halls,
You may want to try the procedure on this link to help you clear the "Paper Jam". It includes detailed instructions and some illustrations.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | HP Photosmart 8250 InkJet Printer
My hp photosmart 8250 keep showing paper jam but there's no paper jam anywhere. How can I get it to function properly?
Make sure there is no paper stuck inside in the paper. may be there is small piece of paper stuck inside
Just unplug the power and open the cover and remove the toner or cartridges from the printer and manually try to roll the roller and remove the paper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP Hewlett Packard Photosmart 8250 InkJet...
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | HP Photosmart C6280 Printer
Kodak photo paper
maybe its a bit thick the paper try a different make. poundland do a good one.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp 8250 printer paper jam?
If you've unplugged the printer and restarted the PC, you may have to uninstall the driver and reinstall it.
Jan 04, 2009 | HP - HP Photosmart 8250 printer
Photo paper too thick causes jam
You said that the photo paper you used to use was 9 mil, which seems to be well within the product specifications. You don't say the actual size of the photo paper you are using now, just that it is too think. Have a look at the product's specification's page. Scroll down to the Paper Specifications section of the page and see if the paper you are currently using is supported. If not, you'll have to go with thinner paper. Here's the page:
HP's Product Specifications
Sep 22, 2008 | HP Officejet 5610 All-In-One InkJet...
367 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
