Question about York Yankees Bedding MLB Comforter
How does the strap feed through the pullies on my magair 3000 row
I've got no instuction manual, and the ******** the handle came undone. The strap now doesn't seem to sit right.
How do I attach a jump ring to the sandisk so I can attach a strap? Where can I get a jump ring small enough and where do I get a strap?
Hi, if you go into any phone shop and buy one of their straps they come with a cord that you loop through the hole and back on itself and this cant then come undone by mistake, its like a nylon thread that you feed through the hole and then put the end through the whole and pull tight you then just clip the strap onto the clip on the loop part, this is very secure and strong as its made to hold the weight of a mobile phone worn around the neck, how ever if you dont want the long strap you can just use the small loop part to attatch it to a key ring or similar.
I know you may be a bit confused but if you go into a phone shop and take the usb drive with you you will see exactly what i mean, these straps also cost near nothing so you cant really lose.
go into any small phone shop or market stall that sells phone accessories and you will see the neck straps im going on about you have the long neck strap part and this attatches to a small nylon loop that you can feed through the tiny hole on the flash drive
hope fully you understand what im saying.
let me know if you have any problems
Jul 06, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Need instuction manual for weider pro 3000 multigym
does anybody have english instructtions for weider pro3000 I need to reassemble HELP
Jun 01, 2009 | Weider Nutrition Weider WEBE8077 Home Gym...
2001 Ford Taurus, Harmonic balancer removal
I had this problem and had to block the teeth of the harmonic balancer with a 2-ton hydraulic jack handle (use an assistant to hold) while I torqued on the bolt with a 4-way lug wrench and a length of pipe. Took a minute, but finally we heard the "ping" of the seal breaking and were able to remove that BAB.
Aug 03, 2008 | 2001 Ford Taurus
GuitAR AMP AND EXERCISE BIKE
there are many versions of the AC30.... here is one of them Good luck
http://www.blueguitar.org/new/schem/vox/ac30volt.jpg
Jan 11, 2008 | Audio Players & Recorders
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Carseat harness straps
You have to unloop the straps from the gold metal bar. This will allow the straps to be free so you can feed them thru the holes and re-feed them into the proper height hold. You will than noticed that there are loops at the very end of the straps which you can loop back onto the gold metal bar.
Sep 23, 2007 | Baby Gear
Garage Sale Car Seat
If you push down on the top of the handle you should then be able to move it. Also, to remove the straps you have to feed the bottom portion of the straps from underneath the seat up through first and then you should be able to feed through the material to remove the pad.
Aug 18, 2007 | Evenflo PortAbout 5 Infant
York Yankees Bedding MLB Comforter Logo
Top York Sport & Outdoor - Others Experts
Paul Carew
Brandon Berry
Brandon Berry
Shehu Pro
Shehu Pro
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
