Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Tank won't fill unless I push down on flush valve inside toilet
I have a Jacuzzi Era toilet. It worked fine until today; now the tank won't fill unless I push down on the valve inside the tank. Then I have to lift the valve to get the water to stop running into the tank. There are no screws to adjust on the assembly.
  • Anonymous Mar 14, 2014
    Not sure if this is toilet, could not find a number on it but I have number from toilet tank cover, BN 30/31. Tank cover is all I need.
  • 3,051 Answers
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
Posted on Sep 13, 2009
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
Jacuzzi espree toilet leaking water from bowl without flushing. water on floor in front.
Hi!Maybe the problem of your toilet is in the mechanism inside the tank that's why its always leaking.Kindly check the tanks fittings of your toilet and replace it if necessary.
Sep 01, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
I have a Jacuzzi Perfecta commode. It has worked fine until all of a sudden, the tank began filling very slowly. It now takes from 5 to 7 minutes for the tank to fill. I've replaced the flush valve,...
keep going...i mean disconnect the supply line from the fill valve, hold the line into a bowl/bucket and slowly turn the water on. is there pressure? sorry for delayed response if you text me back i will try to answer expeditiously:)
Jul 26, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
Jacuzzi toilets installed one year ago - for the first year toilets filled up in a matter of seconds - now both toilets are taking up to 4-5 minutes to fill up the back tank. nothing has changed - why...
sounds like you may have debris in your lines. I was not aware of this until recently but, you should drain your water heater once a year to get rid of sediments that linger and travel through your lines causing possible blockage problems. Try turning your water valve off. Flush toilet so there is no water in the toilet or tank. Unscrew your line to shut off valve to make sure there's no debris. Good Luck!
May 18, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Jan 29, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
I flush the toilet, tank fills up and cuts off, but the water leaks out, then the tank cuts back on to fill up and this is a vicious cycle.
Go to the hardware store and get a new flush valve flap made by Korky and install it. Your flush valve flap has worn out and allowing water to leak through.
Oct 12, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi espirit less than 1 year old, toilet runs and occassionally makes whisting noise. Sometimes it does not run - there is no pattern to what causes it to run or not run. This started suddently,...
Your symptoms point to a faulty "fill valve" (the piece with the float adjustment), and is most commonly caused by small particles caught inside from normal use or a mineral build up. To save time and energy i recommend you replace it with a Lavelle "Quiet Fill" fill valve available at most hardware or plumbing stores or online. They come with very easy to follow install instructions.
Aug 08, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Replacing flush valve jacuzzi toilet
A fluid master should be universal and as long as it will allow the water to reach set mark on overflow pipe.
May 16, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Dec 28, 2008 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
539 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
