Question about Char-Broil 465133003 Grill
I have a char broil portable tabletop grille. Often the flame comes inside the burner, directly out of the regulator. Is this dangerous? Is there some adjustment I can make that would prevent this from hapenning? This often happens immediately after I open the grille top to check the cooking food.
  • Char-Broil Master
  • 3,411 Answers
Yes it is . if the flame is coming out of the burner you have light back blocked burner or spilt burner .
Posted on Jan 22, 2018
SOURCE: Need instructions for assembly of char-broil gas grill
Need Instructins for Char-Broil Model 4955526
Posted on Jun 08, 2008
SOURCE: Low gas flame
Also read the manual, You must open the LP tank valve very slow, the new tanks have funny safety design, I had low flame on the 2nd use w/full tank and was puzzled because it was high flame on the night before.
Rizzo
Posted on Jul 24, 2008
SOURCE: Char-Broil TEC Infrared Grill the
what do we do about the sputtering tec gas line and no heat on tec burner
Posted on Feb 23, 2009
  • 8 Answers
SOURCE: New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Posted on Aug 05, 2009
97F350diesel
  • 1326 Answers
SOURCE: My Char Broil gas grills flame is taller than it
You need to clean the burners/pathways, its not getting enough oxygen and the flame is starved.
Posted on Sep 05, 2009
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
Will not produce high flame properly
You probably have a bad regulator which you can buy at most stores that sell BBQ's.
Apr 07, 2010 | Char-Broil Performance 463463006
Do you use lava rocks or just use propane flame?
Hello, There should be vaporizer tents over each burner. As a reference you can got to website: http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
and refer to the bottom of page 9 or find your model number and enter it into the search bar at the top right of the Char-Broil website: http://www.charbroil.com/
You can order needed parts from there or from Sears which I have found to be quite competitive on their prices.
If you found this helpful please vote yes. Thank You!!
Apr 07, 2010 | Char-Broil Advantage 463453306
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Why my Grill does not heat up to 400 ?
Do this..... turn on just one burner. Once the one burner is lit, turn on a second burner. If the flame in the first burner gets lower, you most likely need to replace your regulator.
Nov 22, 2009 | Char-Broil Commercial Stainless Steel...
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
Char-Broil 465133003 Grill Logo
186 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Steve Allison
Steve Allison
Dave Cottrell
Dave Cottrell
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
