Question about Cameras
The usb for my camera is not being detected at all , could the plug itself be defective, It was working fine for a long time, not sure if its from the vista updates, but i have tried everything that microsoft and kodak suggested and its still not working
    Brigadier General:
  • 11,967 Answers
Try using a separate card reader to download your pictures to a folder you create on your desktop.
Posted on Sep 13, 2009
Camera turn off USB plugged in laptop to charge ( first charge) the battery, SD class 10 HD card installed, now charging light goes on for a very short time and then goes off . as in fully charged. wh
A better that came with a new camera, most of the time is not defect. Please charge it at least 2 times, before you say it is defect.
If possible, use an external charger, because not all USB ports on a computer can deliver 5 volts and 500 mA (Ampere)
Oct 25, 2014 | Vivitar Sakar - DVR785HD-BLU - Blue 5MP...
I have had my canon s3 for about 3 years now everything has been great until now. I cant seem to upload pictures to any computer now. When I plug in the usb it does not even detect that it is there. I have...
It may need to have cleaned the USB port in your camera. Dust and dirty can cause such failures.
Other reason is that the USB circuitry in the camera's main board is defective.
IF after cleaning the USB port, you have the same problem, a cheap alternative instad on sending the camera to repair, it's to use a SD card reader to download your pictures from the memory card.
Best regards,
Jul 16, 2009 | Canon PowerShot S3 IS Digital Camera
FujiFinpix A607. Getting device not recognised when USBconnecting
make sure the software is unstalled via control panel, ad and remove programs, make sure there no mention of finepix now load the software first, then plus in the camera check the usb cable as well
Jun 14, 2009 | Fuji FinePix A607 Digital Camera
Camera window keeps telling me that the camera is not detected
How about try these again
1- Uninstall all of the software related to Canon.
2- Install the drivers for your Canon ONLY.
3- After installing the drivers, plug your camera to a different USB port. (test your USB is working okay by connecting another USB device)
4- TURN YOU CAMERA ON
5- The drivers for your camera will be installed.
6- After it is finished, click start, then computer. Now you should have one Icon starting with canon.....
If you see this icon, double click on it. You will find one or more folders which contain the pictures stored in your camera. You may now download, delete Etc.
You either have not done above steps correctly, or your cable or your USB port is bad.
Good Luck!!!!!!
Jun 12, 2009 | Canon PowerShot A470 Digital Camera
Camera is not detected by computers I have a Canon SD750. Camera is not detected by the Windows XP SP3. A USB generic driver is added, and that's all. No removable media becames available. Canon software...
You may have a defective USB cable. Try a different cable, or try plugging the cable into a different USB plug on your computer. If neither of these work, the camera may have a defective USB plug on the camera. Double check that the camera is turned on. If all else fails, you can copy the photo files by removing the memory card from the camera and putting it in a card reader built into your computer, your printer, or use a separate memory card reader. You can buy them at most camera and computer stores - they are inexpensive, usually less than $20.
Dec 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Computer cannot detect camera at all!
Can you use a USB card reader? The canon software is great but it best used for using a method called tethering your camera (when you shoot directly from camera to hard drive)
Jul 15, 2008 | Canon PowerShot G9 Digital Camera
XP Computer does not detect
Here are some suggestions:
Try using a new/different USB cable. The ones that come with these players are known to be defective at times.
Try using a different USB port on your computer.
Try it on a different computer.
Mar 14, 2008 | iLO (2 GB) MP3 Player
This works for Windows98
1. Uninstall the Canon camera software.
2. Search for "Canon" in the registry. Delete ALL references associated with Canon camera in the registry. Just uninstalling the software will not work. Do not delete any other references to Canon products (printers, etc).
3. Re-install the Canon camera software.
I've had to do this several times. Works every time.
Jan 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Logitech QuickCam Fusion - camera not detected
Hey,
Have you tried instlling the 10.5 drivers instead of the 10.0 which comes with the retail box?
Check this out
http://forums.logitech.com/logitech/board/message?message.uid=95382
Oct 28, 2007 | Logitech QuickCam Fusion 961403-0403...
Cameras Logo
97 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
