Question about Panasonic CT-36HL43 36" TV
Power surge-no picture or sound, just red blinking power light
Had a power outage,when power came back on, the tv would not show any picture or sound, just has a red blinking light when you turn it on. unplugged it and replugged it back in and no change. its about a 2004 Hitachi 62" wide screen. Any ideas?
    Scholar:
  • 61 Answers
Any malfunction associated with a blinking redlight usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
Electricity came back on after power outage and the red LED blinks and goes of & there is no OSD
If your TV was not connected to a surge protector, it may be damaged. If you still have your warranty, check if it covers power surges.
Mar 02, 2011 | Philips 42HF7444T 42 in. Plasma TV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
KDF70XBR950 red power light belinks 6 times repeatedly
Hi.
You have a power board error, and TV is in protect mode. This had been caused by the power surges.
Try leaving the TV disconnected from power (unplug cord) for several hours, or overnight.
This will allow PSU capacitors full discharge and can fix PSU fault after power surge. If it does not correct the problem , then there is a faulty component.
In that case the TV must be tested and repaired by a technician.
Regards.
Oct 21, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
May 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Feb 13, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Tv dont come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | RCA D34W135D 34 in. TV/DVD Combo
Tv won't come on
Nov 07, 2007 | Televison & Video
Panasonic CT-36HL43 36" TV Logo
365 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
