Question about LG ALLTEL AX275 Cellular Phone
Wat do u do if u are bored at 11:35 - LG ALLTEL AX275 Cellular Phone
My honda activa is giving only 28kms and i consulted to honda show room he suggest me to change corporater,bore work&totally engine work wat should i do plz rly me soooooooon
show room people are sales people and and are employed to make sales
best information is to have the fault codes read by an accredited service shop and decide what to do from that advice
I take it that the 28 lkms is the fuel economy and it should be better or it is limited to 28 klms /hr
both indicate a sensor problem and having the fault codes read would reveal where the problem is occurring
any way a simple compression test will reveal the condition of the bore and motor
Oct 18, 2015 | Honda Motorcycles
Wats d gap in rings and n how many kms does the engine has to run
A general rule of thumb for ring gap is .003 " per 1" of bore. Example 4" bore minimum gap at bottom of cylinder for the ring is .012". IF fitting new rings then push the ring to the bottom of the bore ( smallest dia.) and measure the gap . nothing under .010". Max ring gap at this point should not exceed m.025" and if the gap exceeds this then the sides of the rings will have sharp edges from wearing on the piston lands.. The distance travelled depends on the service interval and the air cleaner being used as a dusted motor will need new rings within 15.000miles. and a well serviced motor can exceed 150.000miles before the rings need replacing
Apr 21, 2014 | Cars & Trucks
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Mar 15, 2014 | 1999 Daewoo Lanos
Bike probllem
Without pulling the motor apart there is no way of telling, maybe the bearing caps were not tightened, possibly the ring gap was wrong and it seized in the bore and broke the rod, there are lots of options which the only way to tell is to get dirty and pull it apart.
Mar 09, 2012 | Aprilia RS 125 Extrema Motorcycles
I want more power in my bike. i have v force 3 reeds but not enought wat can i do on my carb wish size of jets can i use to have more power and wish is the better fuel ratio to mix.
the way u can get more power that u can really feel is to do two things, bore the engine out for a bigger piston size and port the engine, 2 stroke engines respond well to these changes, consult a shop on the job, it is not something an amatuer can do, u need specail skills and equip, the carb will also have to be rejetted.
Jan 08, 2010 | 2004 Suzuki RM 125
I want to hav a at sats but it is so boring learning it wat do i do
There is a law of Thermodynamics which, translated in simple terms, states that you cannot get something for nothing. Thre is no free lunch.
If you want to get an A in statistics you have to deserve it. That means be present physically and mentally present in class; take notes; read the notes; do the homework; ask questions, read around the subject in your everyday life.
Now it is up to you.
Sep 16, 2009 | The Learning Company Achieve! Math &...
01 ttr 225 smokes alot when start up
Sounds like time for a top end job. New valve guides, ( lap the valves ), new piston and rings and possibly a new bore. Some bikes have nickle coated sleeves and cannot be bored, You can get a new nickle sleeve to replace the old one. Your dealer will be the best person to say if you need a new sleeve or not. Parts are around $275 with a new sleeve.
Your best buddy didn't put a shot of oil in the gas tank did he? Drain the tank and put the gas in your lawn mower. Sorry to be the one with the bad news. At least now ya know what ya gotta do.
Please rate this answer. Thanks gunman_54321 < cool name
Apr 20, 2009 | 2002 Yamaha TT-R 225
LG ALLTEL AX275 Cellular Phone Logo
42 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
