Question about GE GSS25LGM Side by Side Refrigerator
Whirlpool Estate series fridge/bottom freezer no longer gets cold
This is an older fridge, we bought it used and have had it for 20+ years with good service. However, for several days now it has not kept contents cold enough--milk clabbers within a few days, in the freezer ice cream is soft. We've cleaned the coils, of course, with little effect if any, and turned the thermostat further toward cold with no change. Suggestions?
  • 4,059 Answers
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 13, 2009
Whirlpool fridge and freezer 5 years old, won't stay cold enough
Brush are vac coil in back of fridge, take everything out of freezer and clean inside make sure any drain lines in freezer and bottom of fridge are unobstructed, a small piece of wire ran in and out of these tubes will unstop them. This fixed my fridge.
Good luck
Aug 16, 2009 | Whirlpool Refrigerators
Whirlpool estate, is no longer cold, for the freezer or icebox
hi,
pull it out and study the back of the fridge down where the cardboard cover is, ((careful of the water line)) sometimes the cardboard cover will come loose and get in the way of the small fan back there, if it does , it will do that, if thats not it, probably your best bet will be to call and have a guy come out and test it. craigslist has cheap side by side fridges, since theyre such a pain to replace..
good luck
J
Jun 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Refrigerator in not working
Sounds like the compressor is broken, it could also be a thermo cut out switch that is situated near the compressor at the back. Good Luck the Yeti
May 20, 2009 | Whirlpool 19.8 cu. ft. Side-by-Side...
Viking Pro VCBB36 -warming up + alarm
Over the past several years my heat alarm would come on, first time I called a PROFESSIONALLY, he told me to unplug for 24HOURS, than start it. The solution worked for two years, just happened again, unplugged it for 24 hours, and it seems fine. My guess it must need to defrost. Good luck!
Apr 22, 2009 | Viking Professional Series VCBB36 Bottom...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool fridge with top freezer.( no ice maker )
check if you have frost build up at the back side of the freezer section.
if you do, then it is a defrosting problem.
you could have a problem with the defrost timer, the defrost heater , or the bi-metal.
if there is no frost accumulation, that would be something more and you have to elaborate on what you observe with the unit to help me further troubleshoot your unit.
tnx 4 using fixya,
drcool
Sep 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge not getting cold
This is a frost free frige, so if you see frost, that is the problem. Check the defrost heater, defrost limit and defrost timer/board. You can get by for a while by manually defrosting the fridge. Turn it off, unload the food, and leave the freezer door open for 24-36 hours.
Jul 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
182 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
