Question about Mitsubishi WS-55311 55" Rear Projection Television
Replacement of the green lamp(picture tube) in a Mitsubishi 55'' rear projection HD TV. Lamp is out. Other two (red & blue lamps are fine.) How to remove lamp/picture tube? Price and availibilty of replacement part.
  • 60 Answers
You can probably purchase a smilar set on Craig's list for $300.00, at least that's what they go for in the Austin Texas area.
A new tube may be too expensive and difficult to replace.
Posted on Sep 13, 2009
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
Picture stays on for a few minutes then turns off.. what could be the problem? light bulb? can i do it myself?
This model TV is a CRT projection and does not have a lamp. It has 3 CRT tubes (Red, Green and Blue). Unfortunately, you may need to have a trained TV technician diagnose this further.
Nov 04, 2013 | Mitsubishi WS-55613 55" Rear Projection...
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Replacement lamp/bulb for a Philips 51PW9303
Call Encompass electronics 1-800-638-3328 also part # is on Tube you have a RED/GREEN/Blue each tube has part number on it.UNless you have DLP TV then it would be a Lamp.
Sep 19, 2009 | Philips 51PW9303 51" Rear Projection...
Mitsubishi lamps
This set does have a lamp, it utilizes 3 picture tubes (red, green, blue) The tubes are not available as new any longer. It is recommended to replace all 3 after the reaches 5yrs of age because a new tube will over drive the others in brightness but it is possible to only replace the defective one. You can try Tritronics at 800-638-3328 for rebuilds.
Nov 11, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
431 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
