Question about Garden
Broken plastic housing on Sears String Trimmer
I have the Sears Craftsman Professional Commercial Grade 32cc engine Weedwacker/String Trimmer. I removed the cover over the air filter and the frame into which the cover fits, cracked. Can this be repaired easily by the owner? Does Sears repair this for free? I have only used this product around my home. I am eager-to-learn, but a very low-level ''wrench.'' According to my ''schematic drawing'' the part appears to be the Air Cleaner Assembly (part no. 763-05843) Any help greatly appreciated. --Brian
5 Suggested Answers
SOURCE: have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
Posted on May 10, 2009
  • 41 Answers
SOURCE: No spark Craftsman 989.796060 32CC string trimmer
I believe there is a t20 trox screw holding the clutch cover on. Look down the hole where the drive shaft would insert. After you get that off, the clutch itself needs to be pulled off of the shaft. DO NOT BEAT ON THE END OF THE SHAFT. You may need a small puller to get it off.
Posted on Aug 02, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
nova2nv
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
Stay running
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Jul 07, 2013 | Craftsman 29cc 4Cycle Straight Shaft...
Edger blade quit turning on convertible weedwacker
One of 2 things...drive cable broken or clutch spring broken
Sep 10, 2012 | Sears Craftsman Convertible 25cc 2 Cycle...
Weed wacker started and wacked some weeds then the strings stopped rotating but engine very strong
pull off string housing check that all parts are there. run machine and see if shaft is turning-- if it is then put housing back on sometimes I havent put the housing on properly. if shaft is not turning. then repair is needed. or just buy a new one. cost of repairs on this stuff is not worth the cost. unless it's a profesional grade machine..
Jun 18, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
Was given a craftsman 32cc weedwacker. no manual. need to know what fuel it takes.
The website just says gas/oil (http://community.craftsman.com/Craftsman-Convertible-32cc-Gas-Line-Trimmer-reviews?tab=details). I'm not sure what that means. But on the Craftsman Community web page (http://community.craftsman.com/community) there is a link that says Feedback and Support. If you click that and fill out the form, someone should get back to you.
Hope this helps!
Jun 17, 2011 | Computers & Internet
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
Need to know the 2 cycle oil to gas ratio for a craftsman 32cc weedwacker trimmer
My Craftsman 31cc 2-Cycle Gas WeedWacker Model C216.51318 manual calls for a Fuel Mix (gas:oil) of 32:1
Jul 11, 2010 | Garden
Craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Sep 03, 2009 | Craftsman Convertible 25cc. Gas Line...
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
