Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
Video won't work using the s-video connector.
  • 3 Answers
Which iPod model are you using? Not all iPod models support video with the iDJ2. Check the iPod compatibility matrix document at www.numark.com/idj2 to see if your model is supported.
Posted on Sep 23, 2009
How to connect 520 to a tv
In the Quick Reference Guide ()
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d520_setup%20guide_en-us.pdf, at page 12, you can see 2 connectors that can be used to connect your laptop to the TV (4=S-Video TV-out connector and 6=video connector).
Depending of your TV (type and model), you can use one or both of theese connectors. For an analog TV you can use only the S-Video TV-out connector, using a proper cable (S-Video to S-Video or S-Video to SCART). For a digital TV (LCD, LED) you can use also the video connector (D-Sub 15 pin), if your TV is equiped with a similar video connector. If not, you must use a converter, but is more expensive.
In all cases you must use a second cable for the audio signal (see the audio connectors, at page 11).
Aug 09, 2014 | Dell Latitude D520 Notebook
Component input won't work
There are 2 rows of RCA connectors on the back of this TV.
If you are looking at the back of the TV, on the right side you'll find the connectors.
On the bottom row, left most RCA jack is the Video in for the Component video.
on the top row, the right 2 connectors are for Audio connections.
we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
Sep 24, 2012 | Emerson LC391EM3 39 in. LCD HDTV
My Epic 425 Mx motor won't run even though power is on and display works
try to RUN the software calibration for diagnose, troubleshooting, fix it.
2) LUBE THE deck belt , this happen because the lack of maintenance schedule, maybe the deck is worn and need replace it. see the video and picture
3) lube the rollers bearing too very well.
4) test the input voltage motor, if there are the motor NEED repair,tight any wires connector for loose
5)measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. use the DVOM OR VOM in both cases.
see the block d, tight any wires connector or wires looses
God bless you
Jul 29, 2012 | Epic 425 Mx Treadmill EPTL88105 !
The screen blanking out every 5 mins
Check your Video Card fan if working properly change it immediately if not because it may cause totally damage on chip of your video card. If the fan is working properly check if the heat sink of your video card is in normal heat. If working normally check the PCI slot, clean the connector using the pencil eraser. If your computer not using a video card check the power connector of your hard disc if not loosen clean the terminals and connectors of your hard disc. If the problem is still occur one of the transistor on your motherboard is corroded.
Jul 12, 2011 | Computers & Internet
No video from dazzle to pc
Hi and welcome to Fixyah,
I have something that can help you with, please checked if this is the same settings.
If you follow any of the videos, it won’t work!
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100.
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
Let me know what happen.
Apr 09, 2010 | Pinnacle Dazzle DVD Recorder
How do i connect dazzle to tv to record ps3 gameplay
Welcome to Fixyah.
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task.
Step 4: Plug the Yellow, Red and White RCA connectors from the PS3 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Regards,
Mar 20, 2010 | Pinnacle Dazzle DVD Recorder
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
Steps to set up VGA
Well you can't. You can, however use the S-video to S-video connections or S-video to composite (RCA jacks) connectors and bingo! Knowing what laptop you have would have made my answer more direct as a 20 year old 50lb laptop might have a connector of a different kind like a VGA 15 pin connector with a bunch of DIP switches that will work for an Apple or a PC but my crystal ball shows a modern laptop with an S-video output connector. ~Steve
Oct 20, 2008 | Vga (CAT5-1000S/R) (EXTCAT51000)
How do you get to s-video on a durabrand tv, av button just goes from tv, to aux one (rca in back) to aux two (rca in front) then back to tv again?
Check to make sure that your series of set has an S-Video connector on the input panel (usualy located on the rear side of the set).
In most TV sets, the S-Video is shared with video input 1, and or 2.
For example, if the S-Video connector is located at position 1, then make sure that there are no other connectors in the video connector for the base-band video feed. The audio connectors will be okay, because S-Video does not carry the audio.
When using S-Video, the L and R audio, and the S-Connector video input will be used on the respective video input.
Jerry G.
Oct 02, 2008 | Televison & Video
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
227 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
