Question about Motorola Mobility RAZR V3
Do not know how to fix an axle hinge cover on motorola razr phone, does it just snap on? Does it need a screw? Can't find where screw goes. Do you have to take phone apart?
How to remove a battery from Droid Razr
Ignore some of these my gently pop the back. Off thru the seam. U can do it with your nails. It's glued to the batter so. Use something like a. Butter knife and work it down thru but pushing up not. Down. You don't wanna puncture battery. Separate it from the battery. Then remove. The red. Rubber protector. Over the two. Screws St the. Bottom. Left I. Think. It is. Remove screws then use the tab that says pull to remove or whatever be careful. Not to tear the flex cable.... Those batteries aren't cheap
Aug 20, 2012 | Motorola Mobility Droid Razr
Looking to replace speakers and don't know how to take apart
browse to the internet for motorola razor v3 dismantling
Oct 11, 2010 | Motorola Mobility RAZR V3
Motorla razr v3xx
well pop the back off ,remove the battery.then there are 2 screws that hold the modem in place.remove them and very carefully pry the modem off.there are 2 plastic tabs near the bottom of the phone 1 on each side.careful or they will break.`then there are 4 screws on each side of the screen,when opened..they are under little rubber pucks.remove them and separate the 2 half's..Unplug the flex cable from the screen and carefully remove the screen and camera assembly.be carefully not to tear off the flex cables that hold the 3 buttons on the screen in..then if you'll turn the phone back over.where the battery goes in on the hinge .you'll see another screw.remove that and flip the phone over again.carefully pop the chrome hinge pin out.then you'll be able to separate the 2 half's.then there are 6 little metal tabs that hold the keyboard in place.pry them up and carefully remove the keyboard and flex cable.careful around the hinge,where the flex cable runs threw.
now moving on to the modem, on the bottom you'll see 2 little plastic tabs carefully open them and remove the brass retaining wire and the modem will then come out..get your new covers and reverse this process and you'll be good to go.
May 11, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
The inside screen of my envi2 is not working
buy u a set of very small tork scew driver set for phones,ebay has them ,there are 4 scews that holds screen together,carefully open screen cover all around until it snaps off,then trace flex cable down to corner toward hinge,cable should be loose snap back in carefully.,turn your phone on ,hope that helped.
Feb 04, 2009 | Motorola Mobility RAZR V3
"Bolt" replacement on Razor Phone
Be very carefull with the phone. The main cable runs through that left side.
Look on Ebay for a Left hinge pin for the V3. Also knows as the left knuckle.
Make sure you look for the V3. Not Razr.
If your speaker goes out, or you lose display before you get the Knuckle, you need to get a keypad flex also.
If not, get the Knuckle, and it just slides in. MAKE SURE before you pop it in that there are no pieces of the old one in there and that you don't pinch that cable.
I can fix it for you if you send it to our business, but if you're careful, you shouldn't have a problem.
Jul 31, 2008 | Motorola Mobility RAZR V3
Tries To Come on, But Screen Will NOT Light Up!
hi there.
the problem your having is caused by a ribbon that connects the screen and the mainboard in the phone.
the ribbon seems to have either come loose or detached.other than that being a problem it will almost certainly be a screen issue where the lcd has burnt out.
but in my professional opinion it will almost certainly be a ribbon issue
Dec 09, 2007 | Motorola Mobility RAZR V3
Motorola razr v3: hinge on left side fell out
I know what you r talking about because the hinge on my phone is loos, it didn't fall off yet. I have the blue razr but it's with t-mobile and it's unlocked so they wont fix it. T-Mobile is very helpful but u should call moterola and they will fix it 4 u. And if they give u a hard time talk to the manager.
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola v3
You can buy snap on covers for your phone. you can get them from your service provider or a cell phone accessories store, if your talking about the hard case cover that is on your phone examples silver, black, red, pink, blue, gray, etc. i'm pretty sure that you can't.
Feb 06, 2007 | Motorola Mobility RAZR V3
Drop Razr and inside display screen is white
there is 1 or 2 flex cables in the phone on the flip part. ( display board) you an check & make sure those are properly seated. open the flip you will find 1 small round piece of rubber in each corner underneath is a torx 5 or 6 screw. remove those. then very gently using a flat screwdriver. pry appart the phone. u must start at the hinges. on both. sides. with the screws out, only 4 clips hold the cover on. hope this helps.
Dec 22, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
