Question about Cycling
Hi, I am having great problems getting the bead of the tyre onto the bead grove on the rim. The majority of the tyre goes on ok but a small section on each side won't go on which causes the tyre not to be balanced and is then like riding with a buckled wheel. I have tried stretching the tyre, over inflating the tyre & hot soapy water. Over inflating has had limited success with my off road tyres but has not worked for my road slicks. Any help and advice would be greatly appreciated. Thanks
  • 484 Answers
Using a technique for setting the bead on tubeless tires, i have had a little success, but some wheels are a real pain to set beads on. Anyway, the technique is to get the tube into the tire (which is ready to be seated) and inflate it just a little bit. Don't screw the collar nut onto the valve stem but leave it off for now. Now pinch together the beads of the tire and get them to sink under the tube and into the groove that runs in the middle of the rim. When the beads are down in there, then pump away and seriously go after it; the faster you can get air in there the better. Over inflate, but not more than you feel comfortable with: i have gone as far as 20psi over recommended pressure. The last ditch effort, if all else fails, is rolling the bead into place manually with your thumbs and some elbow grease.
Regards,
matt
Posted on Sep 13, 2009
There is a nial stuck in my tubeless tyre, it is a headless nail but I cannot grip the nail as it is about 3/4 mm inside the tyre, can I plug it by pushing the nail further inside?
Hi Elferns
Yep! You could do that
But the nail might damage the insides as you hit bumps.
Its a bit long winded but if you prop the car up on a jack and let the tyre down then break the seal from tyre to rim, you can reach inside with pliers and pull it out.
Also Better to use a marker on the outside to mark the entry point. You can buy a small kit with tools & rubber bead to push back in the original hole. The tool pulls out and leaves the rubber bead behind. Cut off excess.
Some people don't... but I prefer to coat the rubber bead with the included rubber glue before pushing into the puncture hole.
Kit available at 4WD shops.
Cheers
Feb 19, 2015 | Cars & Trucks
What's the biggest tire I can fit on a stock height 95 gc 2wd on 15x7 rims with no problems?
probably be a 195 ?/15. talk with a tyre dealer as the width of the tyre will depend on the bulge past the rim edge. If the beads of the tyre are not within a distance then the tyre will wear either on the centre of the tread (177 will make the beads be too far apart and so bend the centre of the tread up off the road regardless of the pressure) and anything over 205 will have the rim running on the side wall of the tyre resulting in tread wear or beads coming of the rims. I am thinking that a 195-65/15 will be the recommended tyre for what you ask but TALK TO A TYRE DEALER as tyres are expensive and the wrong size tyre for the rim will make you illegal on the road.
Nov 19, 2014 | Cars & Trucks
How do i take the rear tire off of my tour deluxe
Go the venturers.org website. They have a wealth of information for Yamaha Ventures and also Tour Deluxe which is extremely similar in parts and manufacture.
Oct 08, 2014 | 1997 Yamaha Royal Star XVZ 1300 A
My tire size is 185/65 R 14. can I changed or put tire 195/60 R 15?
No ---not unless you put a 15" rims on the car. The tyre sizing reads like this
185 is the width of the rim from bead to bead in millimetres
the 65 is the profile height --- distance of the rim from the road surface
r is for radial
14 is the rim diameter in inches
now you can understand why a 15"tyre will not fit a14" rim
Jan 28, 2014 | 2005 Honda Civic
2004 kawasaki 110cc took apart back tire area and have a thick metal cylinder shaped object and forgot where it goes
hi there hicks32
that metal object is a rim loc , it should have a rubber top bonded on it , this fits into another hole other than the one that the tube valve stem goes into
you should have 2 holes ,fit rim tape, fit one side of the tyre bead, instal rim lock ( with rim tape running over the rubber on the rim loc ) fit the washer and nut losely on the rim loc bolt stem by at least 4 or 5 threads fit the tube as you normally would, push the rim loc stem fully up ( so that the nut rests on rim )do not let the rim loc stem receede into tyre ) refit the other tyre bead and inflate the tyre and seat the beads on the rim , tighten the rim loc nut and the valve stem nut
make sure that that both rim loc and valve stem are straight when inflated and tightened
refit your wheel
cheers pauly46
Jun 08, 2011 | kawasaki Motorcycles
I have bought a 2nd hand Kettler go Kart with tubeless pneumatic tyres. 3 of the tyres are uninflated and the footpump will not fix them because the tyres have shrunk off the wheel rim and are no longer...
use washing up detergent around the beads of the tire and press them over the ridge in the rim
remove the valve in the stem and use a big capacity compressor to blow the beads in place
replace the valve and inflate as required
r
Oct 12, 2017 | Toys
Ive just brought a new tyre for the front of my gsx600f and it needs inflating every 3/4 days. if its the valve how can i fix this also is it likely that this could have happened when the tyre was changed
yes it could have happend then, check and see if the tyre is on the rim properly,is the bead on the rim all the way round ?, check the valve for leaks with some water or some dish soap you will see bubbles where the leak is.
the valve core can be replaced easily with a valve core tool from an auto accs store, if the bead is not straight deflate the tyre and reseat the bead by turning the tyre on the rim
Jan 16, 2010 | 1991 Suzuki GSX 600 F (Katana)
The front rim keeps bending when I hit hit a small rock/ditch
the suspension is ok buddy the tyre should be a 36psi you dont want them too soft as they will bend again you want the tyres hardish bud
Sep 21, 2009 | 2008 Suzuki DL 1000 V-Strom GT
I cant remove the tyre form my wheel.
I personaly wouldn't recommend loosening any spokes,ive never had to do this and you could get into all sorts of bother trying to straighten up the wheel afterwards.
First make sure that you have let down all the air out of the inner tube (if theres any left).Next with both hands grab the tyre and make sure that the bead of the tyre (where the tyre sits in the rim of the wheel) is loose and away from the rim (sometimes the bead can get stuck against the rim and this will make it much harder to remove the tyre).Do this all the way round the tyre and on both sides.Now if you have a very good quality tyre lever,wet it slightly and the tyre casing as well with some soapy water and try to lever the tyre bead up and over the edge of the rim of the wheel.While holding this position use a second tyre lever in the same way about 2 inches further away and do the same thing.Once you get both levers down you should (hopefully) find the rest of the trye starts to come off a bit easier.Just wiggle and push one of the levers along the bead of the tyre until most of the tyre is off and your there.
Putting the tyre back on is just as much fun!Only try not to use the tyre levers as much as you can very easily damage the new inner tube that your trying to put in.So eat 3 weetabix and you should then have the strength to attempt this.
Good luck
May 21, 2009 | Maxxis Minion Dhr Single Ply Freeride...
Tyres
If you are considering racing in F4 or Buckets on your motoFXR you have a choice of running street tyres (BT39 are great) in the production class or you can fit slicks and run in the Super Bucket class (these are South Island Classes) if you fit slicks on stock FXR rims you need to run tubes inside , the slicks are 95/70-17 fronts and 115/70-17 Rears, same as RS125 GP bikes use, this is not a perfect solution as the rims are slightly narrow and the contact patch on the ground is not optimum. To get a really nice profile on the tyres you can fit some other rims, my bike has RG200 rims and the tyres fit great, GSXR250 rims are good also they have a 2.5” front and 3.0” rear, there is a wee bit of machining to be done at each end as the front bearings don’t fit the fxr axle and the rear disk has to be moved inwards aprox 10mm. Usually the slicks we run on F4 or Buckets are used RS125 tyres which are relatively cheap but sometimes hard to find. A 15hp bike doesn’t exactly eat tyres like a 50hp bike so they last for ages, if they are a bit hard you can borrow a grooving tool and cut some groves in the tyre, this makes them heat up more, also it makes you feel better about riding with slicks in the rain
Nov 10, 2008 | 2001 Suzuki FXR 150
Cycling Logo
204 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
