Question about Canon PIXMA MP530 All-In-One InkJet Printer
Printer stops half way through job saying error
Printer stopped
Try simply adding a printer. If you get an error when you select "add printer" then you may need to check your print spooler.
If there is no error when you select "add printer" then the driver is corrupt and you will need to uninstall and reinstall (make sure you are the admin).
Thanks,
Pat
May 20, 2010 | Brother MFC-8460N All-In-One Printer
HP 5440 printer will not print or test print; no paper jam; disconnected USB cable at both printer and computer; cannot empty print quieu(error oxooooooo5); cartridge track not stuck
I had the same problem.I bought another printer.
Temporarily here is what I did. I used a USB cable that has lights. Whenever the print spooler jammed, the light would not be on. Then go to START, RUN, type in "CMD". This open a DOS window. Type "NET STOP SPOOLER". Wait for it to say it has stopped. Then type "NET START SPOOLER". It will start, then you can close the DOS window.
Unfortunately this helped only half the time. Some times I would reboot, only to have my job print on restart!!!!!
good luck
Feb 22, 2010 | HP Deskjet 5440 InkJet Photo Printer
HP L7780 error on printing.
Uninstall completely all of the software that came with unit and then reinstall it.
And HP customer service sucks - they will only help you out during the warranty period of their product.
Mar 22, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
My printer keeps saying this document failed to print before it prints or half way through the job
When I go to print a document it feeds paper through without printing anything ... my x63 keeps saying clear system error then press clear. ...www.fixyourownprinter.com/forums/inkjet/13953
Dec 06, 2009 | Epson Stylus R265 InkJet Photo Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
Can't remove program from computer because task stopped during print task
you might have a print job in the spooler, right click on your printer icon, select open and right click on any jobs, and select delete.
Apr 19, 2009 | Office Equipment & Supplies
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Printer stops jobs for no reason
your mac should tell you what do to. But go to where your printer is listed, OR delete your printer, then re-install. go through the motions.
Mar 23, 2007 | Lexmark JetPrinter Z22 Color InkJet
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
279 people viewed this question
old marine
old marine
