Question about Brother MFC-8860DN Printer
Will only print one page at a time and then get error beep.
How do I find out how many pages are on the current drum in my Brother 2820 machine
You must enter in maintenance mode:
Press the Menu/Set and Start keys. Next press the key four times to make the machine enter
the maintenance mode, or turn on the machine while pressing the menu/set key.
The machine beeps for approx. one second and displays "MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the
machine is ready to accept entry from the keys.
Display of the Equipment's Log Information (Function code 80)
Function
The equipment may display its log information on the LCD.
Operating Procedure
(1) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode.
The USB serial number appears on the LCD.
(2) Press the Start key. Each time the Start key is pressed, one of the following log
information items appears on the LCD in the order given below.
1) Jam count, indicating how many times a paper jam has been occurred
2) Page count, indicating how many pages the photosensitive drum has been printed
3) Total page count, indicating how many pages the equipment has been printed since
produced
4) Drum count, indicating how many times the photosensitive drum has been rotated
5) Drum change count, indicating how many times drum replacement has been made
6) Toner change count, indicating how many times toner replacement has been made
7) Copy page count, indicating how many copies have been made
8) PC print page count, indicating how many pages the equipment has been printed as
an output device of the connected PC
9) FAX page count, indicating how many received FAX pages have been printed
10) Error code of the most recent machine error *1
11) Error code of the most recent communications error *2
12) ADF jam count, indicating how many times a document jam has been occurred
13) ADF page count, indicating how many documents have been fed
(3) To stop this operation and return to the equipment to the initial stage of the maintenance
mode, press the Stop/Exit key
To exit maintenance mode press 99
Mar 07, 2011 | Brother IntelliFax-2820 Laser Fax
Re:bjc80 prints one page, then beeps 8 times and error light flashes
8 times is abnormal temperature of the printhead. You need to replace the printhead.
Dec 29, 2009 | Canon BJC 80 InkJet Printer
My Canon s4500 not working, with 6 beeps error
This is because the BJ Cartridge is not installed. Please refer to your manual page 214.
Two beeps: Out of paper, or paper feed error
Three beeps: Paper jam
Four beeps: BJ Cartridge out of ink
Five beeps: Cartridge not installed correctly
Six beeps: BJ Cartridge not installed
Seven beeps: BJ Cartridge defective
Eight beeps: Waste ink tank almost full
Nine beeps: Automatic print head alignment failed
The POWER lamp flashes orange and green alternately with beeps: Service error
YBC (/\)
Oct 08, 2009 | Canon Office Equipment & Supplies
34 short paper
The printer does not auto detect your paper size and so when your Legal size document was printed on Letter size paper, you get a 34 Short Paper message.
Feb 07, 2009 | Lexmark C510 Laser Printer
My HP Laserjet 2840 all in one beeps when printing
unfortunately, your printer uses all of the carts even for just black prints.
press the check mark key and scroll down to diagnostics.
select disable cartridge check
But then you won't know when you're out of a certain color.
Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Canon BJC 85 printer
PRINTER BEEPS (5) TIMES, ERRORS
Nov 29, 2007 | Canon BJC-85 InkJet Printer
Brother MFC-8860DN Printer Logo
83 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
