Question about Gaggenau VK 230 Rice Cooker
Gaggenau steamer wont work
I have replace all electronic parts on my vk230 610 steamer and still getting an F1 when I try to power up the steamer. Timer works and so does drain.
2 Suggested Answers
SOURCE: gaggenau vk230 steamer doesn't work
Are you sure the child lock feature is not preventing it from working? Exactly what is the problem? Is the display blank? Is the problem that it just won't heat? Are there any error codes in the display?
I also have a VK230 that is having problems and am gaining experience with troubleshooting this steamer. Gaggenau is very difficult to work with and it is difficult to find a service company that is knowledgeable about the brand.
Are you interested in selling yours? Parts from yours may help me fix mine.
Posted on Jun 30, 2009
Kenmore code F1 and broil wont go off
he clock on my STOVE started flashing F1
  • You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
      NOTE: Some models incorporate the touch pad and the clock as one part.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Oct 24, 2013 | Whirlpool Accubake RF362LXTT Electric...
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
F1 flashes after unit has been plugged in for awhile. It works, but we have to unplug it to get rid of beep and F1 message. Any ideas?
If you dotn find this new part in your store, check THIS LINK to repair service.
Hops helps.
Apr 18, 2011 | Kenmore 95042 / 95044 Electric Kitchen...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
What does the f1 message mean?
this is your part, and f1 code is the board. Always visually inspect the bad part though before ordering but this should fix ya.......good luck..
Electronic control:
http://www.repairclinic.com/referral.asp?R=154&P=496226
Nov 15, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Gaggenau vk230 steamer doesn't work
Aug 10, 2008 | Gaggenau VK 230 Rice Cooker
F1 Error Code
F1 generally means the touchpad or ERC (Electronic Rage Control) is bad. This is what Maytag recommends as a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: - Disconnect power to the range. - Gain access to the back of the ERC (electronic range control, or "clock"). - Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide. - Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC. - Turn the power back on to the range. - Watch for the F-1 and listen for the beep. - If you get the F-1 and beep, replace the ERC. - If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad. NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control. I hope this may help you, but it looks like you may have an expensive repair. Double check your wiring just to be sure.
Jun 18, 2007 | Maytag MGS5770 Gas Kitchen Range
Gaggenau VK 230 Rice Cooker Logo
138 people viewed this question
Top Gaggenau Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Gaggenau Kitchen Appliances - Other Expert? Answer questions, earn points and help others
