Question about Kitchen Ranges
I need instructions on how to use the sabbath mode . the instruction manual is misplaced.
  • 3 more comments
  • sslachman Sep 13, 2009
    rgb745behwh -30'g rng s/c sealed brnr
    rgb745behwh
    hotpoint gas range rgb745behwh
    thanks
  • Eric Duda
    Eric Duda May 11, 2010
    I would need a model number and make t get the correct information to you.
  • Dan Webster
    Dan Webster May 11, 2010
    What brand stove? Would you be so kind as to post a model number?
  • Kitchen Ranges Master
  • 8,220 Answers
I found this for electrolux models on my pc , maybe you can try it on yours or get an idea how it works. All features are about the same.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE
or
SALE with 3 in red. This one is for factory use and
should
stay on USE.
Posted on Sep 13, 2009
  • Dan Webster
    Dan Webster Sep 13, 2009
    This is a good question. Do me a favor. Ask at theses forums please:
    I want to know myself.
    Post your model number at any of these
    fine forums for an answer
    that will save you big money::
    http://appliancejunk.com/forums/index.ph...
    http://forum.appliancepartspros.com/
    http://applianceguru.com/
Tip
Sabb or Sab Explanation for Kitchen Ranges
Here is a useful tip in identifying a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC) or Electronic Oven Control (EOC). An “error” code display of “Sabb" or “Sab” will be displayed and the range or oven will not function. This is called “Sabbath Mode" and it may be costing you unnecessary charges in service call fees. This is NOT a problem, but actually a feature provided by some manufacturers to enable customers of certain religious faiths to honor the Sabbath. The range will not function at all during this period and cannot be reset by unplugging the unit or turning it off. In your owner/operator's manual there should be a section that refers to "Sabbath Mode" under the control panel features and operation. This "problem" is a minor operator issue and is not a malfunction of the appliance. This is commonly reported by customers to service companies to have corrected, but the repair is unnecessary, and usually NOT covered under the manufacturer’s warranty. The reason: It is a designed feature of the appliance and considered “operator error” in most cases. What this means is you may be paying someone big money to push a couple of buttons and “fix” something that could have taken you minutes to correct yourself. Sabbath Mode can inadvertently be activated by pressing the wrong sequence of control panel buttons, or following a power outage. The procedures for turning Sabbath Mode on/off are referenced in your owner operator manual under operating instructions. Manufacturers provide different procedures for activating and deactivating the mode, so instructions may differ. I hope this helps avoid the need for a service calls in the future and saves you money.
on Dec 09, 2009 | Kitchen Ranges
STUCK in Sabbath mode.
What is the complete model number of the unit?
Dec 10, 2012 | Jenn-Air Kitchen Ranges
Trying to set Sabbath cooking mode, no instructions in manual
copy and paste this site......http://www.retrevo.com/search/v2/jsp/pdfViewer.jsp?doc=404215aeb4c28c12002f177f0d2004f4&page=20§id=41&q=KitchenAid+KERA205PSS+sabbath+mode
May 08, 2011 | KitchenAid KERA205P Electric Kitchen Range
I have a error code of 596 6ATH and cant seen to
The error your range is displaying is actually "SABBATH", which is Sabbath Mode. This enables the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question uder is correct, the instructions for Sabbath mode are listed on page 14 of your owner's manual. To cancel Sabbath Mode you press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your correct MODEL NUMBER (if different from the one I provided) and let me know. I hope this helps you.
May 01, 2010 | Maytag MGR5875QDS Stainless Steel Dual...
HOW DO YOU GET THE STOVE OFF SABBATH
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
If the model number you listed this question under is correct the instructions for Sabbath mode are listed on page 13 of your owner's manual. To cancel Sabbath Mode you press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your MODEL NUMBER (if different from the one you have listed) and let me know. I hope this helps you.
Apr 14, 2010 | Maytag MER5775Q Electric Kitchen Range
How set sabbath mode??
to turn on or off the sabbath mode on your oven press and hold the sabbath mode button for 5 seconds that turn it on and then repeat to turn it off
Apr 04, 2010 | KitchenAid KEBC107 Electric Single Oven
Error code 5ab
You inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
All ranges differ in design and features. The instructions to turn Sabbath mode on or off differ as well. The instructions will be in your owner's manual.
If you do not have an owner's manual, or do not understand the instructions, please post back with your model number so that I may be able to povide you with better assistance. I hope this helps you.
Nov 01, 2009 | Kitchen Ranges
Code 5A6 appears when i tried to change the clock. stovetop works but the oven does not
Kitchen Ranges Logo
203 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
