You will see a little "button" you can slide up and down at the side. This controls the write protection. Just like it the other way and that should do it.
And if you are referring to some phone, if this error comes up on the CellPhone's screen, then there are 2 possibilities, the 1st is if your Phone is a Symbian Phone, then its easy to remove this error, and 2nd, if it is non-Symbian then, only formatting with solve the query, means loosing all data.
Regards.
You have to take your Memory card out of the device, and there will be a small slide switch on the side, there will be some indication there.
To make it easy for you I've attached a snap, click here to see.
If I was helpful, kindly do Rate!, and a Testimonial would be much appreciated.
Regards,
Waqar.
