Video Not showing up , no Beap on Pwr Up, just running, Whao I Do?>
  • c_goodenough Sep 13, 2009
    I rebuilt it for someone , then went to finsh up today , and got everything done, ummm restated the computer many times , no problem then i restarted it again later on and when i did, it wud load the windows csreen where the bar is , and then shut off and restart , so i ended up taking it home , and when i got it here , i was pluging it on and all of a sudden it jus styoped wrking , like literally , but i duno if it may have been the ram , becuz i acidently put it in the wroong way i think ( non-purposely) and i started to smell somthin , but i caught it before it smoked u kno , it was really notjhing cant really see any burnt marks anywhere , or tansmitter things burnt , ummm but since then its been not showing any video , no beat , no video , nothing , tried power supplies , tried , pci video card, tried the battery , tried prrty much everythingbut hthe hdd , but i dont think that wud do it .....soo im a little stuck here , and its for an old couple , their already stressed... i had it wrking , and it jus stated messing up.
  • George Logue May 11, 2010
    Could be motherboard gone bad. Have you been working inside the case or did this happen all by itself? You can try replacing the battery on the motherboard. It's a long shot but a cheap one and I have seen it work.
  • 979 Answers
Hello sir, try the following make, sure that your power supply is working fine:
  1. turn off the pc and remove the side cover, locate the memory module, and reseat it (remove and put it back). power on the pc. Still not working? (make sure that the 12 volt 4pin molex power connector is pluged on the motherboard)
  2. off again, remove the memory modules again and clean its gold plated contacts by using an eraser (the pencil eraser) then put it back again. power on. still not working? do 1 and 2 several times. (make sure that the memory modules are good)
  3. If several times has not worked, try to isolate the problem by removing all the connectors except. 20/24 pin power connector, the 4 pin 12volt power connector, the vga cable, front panel leds and switch. do 1 and 2 again.
  4. still not working? check your motherboard connections and review your work?
  5. is you pc 220 v plugged on 110v?
  6. Check *********** board.
let me know your progress.
Posted on Sep 14, 2009
Turn computer on and fan runs loud and monitor will not show desktop although it appears to have pwr.could this be motherboard issue?
Yes! the motherboard may be the issue, first sub out the ram memory one at a time to see if computer can be restored, next remove video graphics card, [if available] and hook monitor to the internal video on the motherboard, if it works it means the video graphics board is defective.
Jun 29, 2012 | Computers & Internet
Planet audio p9740 user's manual
how do I transfer my pic off my digital camera sd card into my p9740 I put the card inside it read it but I can't program the pic to choose one as my screen saver...do u have a solution?
Mar 13, 2012 | Planet Audio P9745B / P9740 Car Video...
Requested sir, My Intel motherboard problem CPU power on, cpu fan ok, keybord light ok, mouse light ok,RAM ok,no RAM beap,no display beap,no display???
Try resitting Memory modules Re-seat vid card if not integrated ,If integrated try
a PCI video card or AGP slot whatever is available integrated video may be defective
usually reinstalling memory and or video card fixes this
Feb 14, 2011 | Computers & Internet
Video will not work on ps3
It may be stuck in the opposite mode of what you are using on the TV like HDMI output or S-Video. To check this press and hold down the power button, you will hear the initial beap once and shortly followed by a double beap. After the double beap immediately remove you finger. You may have to do this once or twice to get the right beap because this is a service menu they do not want you to get into. Once this is done you will have prompts on the tv to change settings to what every output you want. Make sure you change it to the right one and you should be all set.
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
Play station 3 power comes on but nothing works. You can hear that it is powered up.
It's probably not in the setting you chose for example you might be using HDMI and it might be setted for SCART, to simply change this keep hold of the power key until you hear a beap (the first one when you just press the power key) keep hold of it until you hear another beap then let go. The setting should be changed. No problem :)
Sep 30, 2009 | Sony Playstation 3 (PS3) Console
Just went to put my standard radio back in my fiesta and i don't have the keycode the serial number is m527782 thanks
depends whao old it s, iff you need 3 digits keycode its ( 545) or 4 digits its 8345 this is for old fiesta 90/96
Sep 26, 2009 | Car Audio & Video
Need Diagram for the pwr,reset,pwr led,hdd led speaker connections on the motherboard. Model p5s 800-vm.
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for using FixYa!!
May 27, 2009 | ASUS Computers & Internet
I HAVE AN MP610-2G MP3 PLAYER, VIDEO WITH FM RADIO USED IT A COUPLE OF TIMES WENT TO TURN IT ON YESTERDAY AND IT SAY'S FILE SYS ERR I'VE TRIED THE RESET BUTTON BUT STIILL CAN'T DO ANYTHING WHAT NEEDS TO BE...
whao the is really big, what i will ask u to do is to read the manual were it tells u about troblshooting if u have not done that, try to formate it back to factory settings and if the files ae corrupted delete them and upload new ones. i had a similar problem when i just got mine but didn't show something like that, the file were unable to play and it got frozeen.
Jan 12, 2009 | Coby MP-C7085 MP3 Player
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
