Question about Boating
Want to replace the trim/tilt motors on my 1995 Yamaha TXRT 200hp outboards... do I have to remove the motors from the boat?
    Sniper:
  • 53 Answers
No. a unmodified transom bracket may need to be moved not removed. Since the tilt motor is out you will need to manually lift the engine. you can see the picture diagram at www.yamaha-motor.com. click on outboard motors,parts and service, view parts catalog. find your year make and model by following steps listed at top. select power trim and tilt assembly. in the picture you will see the location of the Manuel release valve on the starboard side. turn the Manuel release valve then lift the engine. tie it up or use a stand to keep it up,do not use the tilt lock. with the engine in full tilt position, you can see the motor. some brackets are modified were you can remove the motor without moving the transom bracket. If unmodified you'll need to follow these steps. (1) lower the engine back down.the steering arm needs to be removed from the steering cable and swung forward. do not remove steering arm from engine. on the starboard side of the engine you will see the steering cable going into the steering cable tube. (2)a 1 1/6 nut secures the cable to that tube remove it and slide cable out do not remove it.(3) lift engine again and secure it. your about to remove the motor mount bolt so make sure you secure the motor completely (4)remove upper and lower transom to bracket bolts remove bolts on the port side only.(5) you will see three bolt that go through the transom bracket to the trim and tilt assembly. remove them.(6) if all bolts are removed you will be able to slide the port transom bracket to the left out of the way(7) remove tilt/trim motor.
Posted on Nov 03, 2009
  • rickbarton Jan 02, 2011
    would this be the same procedure for a 1996 C150TXRU?It appears like it would.
Cannot raise or lower 115johnson outboard with manual relief valve open
If, even with relief valve open you can't raise or lower the motor by hand, your tilt tube is stuck.
remove your steering cable.
Remove the 2 big nuts on the tilt tube;
unbolt the engine from the boat
unbolt the trim/tilt system from sb and pt bracket.
Remove brackets. Remove tilt tube from steering bracket
Clean everything
Replace the bushings
Use triple-guard grease everywhere on reassembly
Jul 31, 2017 | Boating
How do I replace the motor on a yamaha power tilt and trim 1995
loosen engine mounting bolts and steering tube , trim engine up by releasing the valve on the side and tie up so not tocome down ! remove pin on the ram then remove all bolts and wires and should come out !
Jul 20, 2014 | Arco Yamaha Outboard Power Tilt and Trim...
How to tilt trim remove
first you have to remove it from the boat. then remove the clamp/bolt plates to get to the trim tilt unit . best left to dealer.
Jul 10, 2014 | Boating
How to remove tilt and trim motor
well you have to remove it from the boat first . then remove the side plates to get to the trim tilt unit .
We have a 1998 yamaha v4 2 strock 115 engine. we can not get the motor to go down. even if we try to drop it manually
lock lever not down ? does it move up and down at all , the tilt tube could be siezed ,both trim solinoides working ? try standing on the engine gearbox as you trim down or manually release ! if then goes down try injecting the grease nipples with petrol via a grease gun that uses tubes like tooth paste and this will soak the corrosion ! then grease and see if free and if not enough then lift the engine off and remove the tilt tube and clean the sleeves and grease and refit !
Apr 09, 2014 | Light Outboard Motor Boat Bass Fishing...
How to replace the mamuel relief value on a 90 hp yamaha out board motor
You have to remove starboard transom bracket,then remove circling from t/tilt release screw,remove screw,left hand thread.There is a flat washer that normally sticks to screw/valve,this needs to be replaced.Its easier to do this with motor trimmed up or if motor is off boat,lying on its side.Very little oil will come out if done in trimmed up position
Mar 29, 2014 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
752 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
