Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Computer says a network cable is disconnected.
Works fine for a couple hours then Computer says a network cable is disconnected.Have tried different cables .
    Problem Solver:
  • 8 Answers
Check to see if the router is hot when it discounts from your system if it is then unplug the power cord for a few minutes then plug it back in see if reconnects but if it continues after a few hours could be signs of a defective router and will need to be replaced and i recommend a LinkSys router its supported as industry standard.
Posted on Sep 13, 2009
  • 22 Answers
Sounds like a loose connection in your PC. Check to see if cable seats firmly and if it wiggles excessively when inserted.
Dynex blu-ray wi-fi disconnects after 1 hour
The issue is with the chip that works with the wi fi. It is erratic in operation. Too expensive to fix. Can you just hook it up via ethernet cable for internet connection?
Sep 07, 2017 | Dynex™ Televison & Video
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Can not connect to the internet through router if i hook up the internet straight to computer it works but when i try through the router the computer has no internet connection but it picks up the router
Some cable modems look for the MAC address of the computer until reset. You can either enter the MAC address from the PC into the MAC spoofing setting on the router OR disconnect and unplug the cable modem for 24 hours and start over. First, plug in the cable modem and connect the cable. 2nd, plug the router cable into the modem and router and plug in the router's power supply. Then connect the computer and it should work fine.
Feb 27, 2011 | Computers & Internet
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
Keep getting message that cable has been disconnected..
First off, you need to update Windows.Go to where your modem is, unplug the ethernet cable from the router and connect direct to your computer, and run Windows update. You may have to reboot several times before all the updates have been implemented.
Then, the flag message you have been getting "cable disconnected" indicates to me that the flag is coming from the internal network card of your computer, not the wireless client in the computer. You need to make sure the wireless client is setup properly to see the router.
Do you know if security has been setup on the router? If so, we will need to walk down that road to get it set up on your laptop.
But first things first. Get the computer updated, and reply back answers tot he above, as well as what Operating System,s you are running.
Feb 04, 2009 | 2wire Computers & Internet
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
128 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
