Question about Polaroid 1911-TLXB 19 in. LCD TV
Tv connected to local cable. No signal warning on
Tv connected to local cable. No signal warning on and I can't find the problem
How do I change from a cable input signal to an antenna input signal on a slyvania TV
I believe that the new flat digital antennas have a coax/cable connection on them. In the menu of the tv. You should select TV or Antenna for an input. You may be lucky and connect the antenna to your cable connector and get some local channels.
You should give us the model number of your set. As each tv is just a bit different.
Jul 30, 2015 | Sylvania LC420SS8 LCD TV
NO SIGNAL
look on the back of the TV and see which input you've connected a cable to. unplug the cable at the TV and then plug it back in and do the same thing at the other end of the cable,this is just to make sure cable is making a good connection. then put the TV on whatever input
Nov 04, 2013 | Televison & Video
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
Nov 05, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
My tv is plug into the cable box and wont pick up any channels when i auto program???
Do you subscribe to cable television? If you do, you will need a cable box to decode the signal, otherwise unless your local provider offers a free to air service, your TV will not be able to decode the cable signal. It is important to know wether you are connecting your TV to a cable socket, or aerial or satellite, as these are all very different signals which your TV may not decode.
Jan 03, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
My panasonic viera started showing a no signal sing on channels 7, 10 and 9. we hav tried re tunin but all we can get is abc and sbs.. CAN ANYONE HELP???
1.Set your TV settings first,if you are installing a cable then set your TV to cable mode but if you seek for local channels set your TV to antenna with NSTC set to program.
2.When tuning make sure that the antenna is connected to the tuner and use a good antenna.
3.If the following procedures above did not remedy the problem,the next procedure is now internal repair.
Warning: This should be done by an expert.
a.Try to replace memory IC
b.If not remedy,try to replace tuner.
c.If not remedy,adjust IF and replace crystal.
Jul 12, 2009 | Panasonic Televison & Video
I JUST GOT A D52W20 HD TV.I SCREWED THE CABLE CONNECTION TO THE ANTENA INPUT. THE ONLY STATIONS I GET ARE LOCAL CHANNELS BUT NO CABLE CHANNELS. WHAT DO I HAVE TO SET ON THE TV OR WHAT DO I HAVE TO PRESS ON...
Before you bought your new TV, was the cable connected to an older TV, and was it working?
When you say you screwed the cable connection to the antenna input, did the cable come directly from the wall, or did it go through a cable box first. If it came through the wall without a cable box, it's possible it's not an active cable account, and you're only getting over the air signals for your local channels (and nothing through the cable). Or, your cable signal might have been analog only, and with the transition this week to digital TV, maybe you're no longer getting the channels broadcast properly.
If you are a cable subscriber, then this problem should be reported to the cable company, and they can do further testing to see what's wrong with your signal.
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Converting my TV
Yore in luck if you already watch TV from a cable provider you will not have any problems when "The big Change" comes next February
Feb 19, 2008 | Televison & Video
Polaroid 1911-TLXB 19 in. LCD TV Logo
43 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
