Question about Water Heaters
I have a VOKERA 24 boiler the Linea range which was working fine until i notes the pressure was a little under 1.5 Barr. I topped it up the pressure with the filling loop every thing was fine. The next day the over flow pipe was dripping . I noticed the pressure gauge was now showing 2.5 Barr so i let some pressure off by the radiator valve. I turned the boiler off to do this. Then i remembered the boiler needed to be turned on so the pump would need to be working. When i tried to turn the boiler back on the digital clock did not light up but it fired up for about 1-2 minutes then it just turned off. I tried to fire up the boiler again but it just makes a clicking sound then stops a bit like a lock out . I have checked the two fuses in the boiler and the fuse on electric plug. Which are all fine could you please help me with this problem. cheers mate
  • 54 Answers
Water logged expansion tank ( ruptured diaphram in tank) or wrong size tank. This caused the excessive pressure in the system causing the relief valve to open. Also, air in the system causing flow to stop, Both conditions will cause boiler go out on safety.
Posted on Sep 13, 2009
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Low pressure on recently serviced Vokera 14/48se.
Identify the cold feed to the boiler, then look for a tap/service valve which when turned lets water into the boiler via a fill loop to pressurise it. 1-1.5 bar is ok
ju
Nov 05, 2009 | Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Vokera linea 28 boiler. I am continuously having to re-pressurise the loop (about twice weekly) also i keep getting a code 3 error appear which i know is a fan flue problem i have reset the boiler. The...
I have a similar problem with this boiler. When CH on, boiler overpressurises, (check relief valve outlet) You will then lose water from the CH loop and will have to repressurise when the CH loop cools. The problem is most likely caused by a loss of air from the expansion tank, which will need re-charged. This is not a big job as it has a standard tyre type valve connection but needs an accurate pressure gauge. Probably best left for plumber.
Mar 12, 2009 | Water Heaters
Fan runs continuously
the air pressure which does not controll the fan it is a safe guard for the gas/oil burner to ignite nowing that the fan is running ( air switch normaly negative /positive prssure n/o,n/c circuits. it could be that your boiler is designed for a cant think of techinacal name but when in centre of house/factory and has 1 or more boilers connected to flue etc the fans run when only power to boiler is on , non vented system ? it could be a simple link to remove in controll panel i would phone technical help for manufacture ?
Jan 31, 2009 | Water Heaters
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
How to bleed a vokera syntesi combination boiler
I think you mean your boiler needs pressurising firstly connect hose hand tight open the non return valve normally teed into a 22mm pipe then flick the valve lever on the cold supply quick little bursts till you reach your required pressure best of luck
Nov 15, 2008 | Water Heaters
Vokera Linea 28 combi boiler
sounds like you have an earth leak or defective pump winding
Nov 04, 2008 | Water Heaters
Water Heaters Logo
465 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
