Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Same problem, but with Lexmark 2600
"Problems communicating to printer... The specified resource cannot be found in the image file."
I can't get my Lexmark X2670 to scan and transfer the document to my computer other than as a .JPG file which is taking up too much space.
Try to access the Lexmark Productivity Studio. Just click on Start > All Programs > Lexmark 2600 Series > Lexmark Productivity Studio.
You can try scanning to PDF. If that option is grayed out, you'll need to install the OCR found in the installation CD of your printer.
Jun 14, 2012 | Lexmark X2670 All-In-One Printer
Lexmark X4580 (all in one wireless)
HI,
You can try out these two options one by one to fix it up:
A)
1 Unplug the printer.
2. Uninstall the drivers.
3. Reboot the machine.
4. Go to the lexmark site and download the drivers.
5. Install the new drivers.
B)You will get the "CANNOT RETRIEVE APPLICATION LIST" if your pc blocks the communication from the printer. This can be configured in your personal firewall. This can be Windows Firewall (found in Control Panel, Security Center), Symantec Client Firewall or similar. Depending on the configuration of this firewall you might or might not get pop-up messages from the firewall during installation. These pop-ups will allow you to permanently allow for this incoming communication. But your firewall might be set not to let you decide anything which will typically mean that the calls will be blocked out. This will often be the case if you have a company laptop configured by the company IT dept. You might then have to ask an admin to add exceptions the applications used by Lexmark as the configuration might not be open for you to change.
I think this is the complete list of applications:
Job Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdijswx.exe
Lexmark Communications System: C:\WINDOWS\SYSTEM32\lxdicoms.exe
Lexmark Connect Time Executable: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxditime.exe
Lexmark Device Monitor: C:\Program Files\Lexmark 3500-4500 Series\lxdiamon.exe
Lexmark Imaging Studio: C:\Program Files\Lexmark 3500-4500 Series\App4R.exe
Printer Communication System: C:\WINDOWS\SYSTEM32\lxdicfg.exe
Printer Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdipswx.exe
Goodluck,
Please don't forget to rate the solution.
Apr 17, 2008 | Canon MultiPASS F50 All-In-One InkJet...
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
My Lexmark X2670 has stopped printing on my MacBook and I receive the following error message Missing component: /Library/Printers/Lexmark/Drivers/.Resources/2600 Series Color 2.lut How do I fix this
go to applications, utilities, and open terminal in the window, paste this: open /Library/Printers/Lexmark/Drivers/.Resources/ It will open the folder where the missing component should be. You will find the "2600 Series Color 1.lut" file. Duplicate it and change the name to 2600 Series Color 2.lut close the folder, and shoot a print, it should work.
Mar 07, 2011 | Office Equipment & Supplies
Quicken will not print. Program aborts after error message: Problems communicating to printer: "Dell Photo Printer 944" The specified resource name cannot be found in the image file.
Ensure that your printer is online and all cables are securely attached.
(i) If your printer is on a network, ensure that your network allows you permission to access the printer.
(ii) If you are printing to paper, ensure that the Quicken PDF Printer is not selected.
(iii) If you have more than one printer:
(iv) Ensure that you have selected the correct printer in Quicken. (Select the QuickenFile menu, select Printer Setup, and select the item you want to print. Be sure the correct printer shown in the Printer field. For example, if you are printing a report, select File > Printer Setup > For Reports/Graphs.)
(v)Try making another printer the default printer.
Microsoft Windows Vista:
Click the Microsoft Windows Vista logo (Start button) and select Control Panel.
Under Hardware and Sound, click Printer.
Select the printer and click the Set as default command button.
Microsoft Windows XP:
Click the Microsoft Windows Start button and select Printers and Faxes.
Right-click a printer and select Set as Default Printer.
(vi) Try printing from WordPad or Notepad to be sure Windows is communicating with your printer.
Click the Microsoft Windows Start button, select All Programs or Programs, select Accessories and select WordPad or Notepad.
Enter some text. Select the File menu and select Print.
(vii) If your file does print from WordPad or Notepad, try reinstalling the printer or printer driver.
(viii) If your file does not print from WordPad or Notepad, it probably means that Windows is not communicating with the printer. Check your Windows printer settings.
Thanks for using Fixya.
Good Luck and have a nice day.
May 25, 2010 | Computers & Internet
My lexmark 2600 , don't scan, or copy. I changed
make sure that all driver are loaded properly so that the pc will be able to understand or can be able to communicate with the printer
Oct 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
Is there a website to download free software for the lexmark 2600 printer/scanner. In order to use with my xp desk top?
Fortunately, there is!
Almost all makers of gadgets offer an area wherein users can download drivers and manuals and a lot of information needed for the device.
Anyway, here is the download link -
http://www.downloaddelivery.com/downloads/cpd/cj2600en64.exe
Just an fyi, it's a pretty big file so downloading may take a while. If you got a fast internet connection, you should not have any problems.
Cheers.
Oct 05, 2009 | Lexmark X2600 InkJet Printer
Lexmark 2600 printing problem
You might try deleting the printer from the 'Printers and faxes' folder in the Control Panel, reboot with the printer connected and turned on. Win should 'find' it again and reinstall the driver.
Dec 22, 2008 | Lexmark X2600 InkJet Printer
I am trying to scan pictures onto my computer using lexmark 2600 series
How to Scan on Imac using the Lexmark 2600:
1. From the Imac Desktop select the Magnifying glass in the upper right corner of the screen.
2. Search for Preview
3. Open Preview App
4. Put item to scan on Lexmark Glass Face down and close the lid.
5. Select File (In Preview from Top tabs on desktop), then Choose 'Import
Image'
6. Lexmark 2600 Series Window opens
7. Change Scan to Folder, Name and Format to your choices
8. Use cursor to highlight area of image to scan in the 2600 Series Window.
9. Hit Scan from the 2600 Series WIndow.
10. Save the file using the File tab in Preview, and choosing Save
Aug 27, 2008 | Office Equipment & Supplies
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
98 people viewed this question
Seeker5211
Seeker5211
