Question about Vehicle Parts & Accessories
Disarming chapman vehicle alarm system on 94 chrysler new yorker
I have no remotes and disconnected the brain module i need to know how to remove alarm completely
    Problem Solver:
  • 16 Answers
If you have removed the brain, I don't see why you need to remove the rest, unless you just want it out of the car. Without the brain the wiring should cause no problems to your car unless there is a bad connection. If you need more info on how to remove the remaining alarm---
remove the siren in the engine compartment. Most everything else will probably be found under dash drivers side. If it has been installed with connectors, remove them at point of connection. If solderd cut at point of connection and use electrical tape to cover exposed wire. You will have one wire connected to the dome light circuit, one to the parking lights, one to a relay to disable the starter. Cut it out and reconnect starter wire. Led, a switch, maybe a button also-not hard but maybe not necessary?
Posted on Sep 13, 2009
Hi need disarming cobra g193 alarm,have keyfobs.almost everytime i disarm alarm door locks start to play up(sounds like them trying open and close open and close) sometimes its even start doing during the...
I would recommend disconnecting the alarm and having it checked out by a qualified installer. It sounds like there may be a problem with the brain of the alarm itself. Disconnecting it will prevent the motors from burning out.
Feb 04, 2011 | Vehicle Parts & Accessories
The panic alarm sounds
it sounds like one of your door switches is setting off the alarm. Or you hood or trunk switches.
Anti-Theft -Perimeter The perimeter anti-theft system consists of the following:
  • door lock cylinder disarm switches
  • liftgate lock cylinder disarm switch
  • generic electronic module (GEM)
  • door open warning lamp switch
  • pulse stretcher module (wagon only, is located between the rear license plate housing and bracket)
  • keyless entry remote transmitter
  • hood switch/bracket assembly
Principles of Operation
Perimeter Anti-theft
The perimeter anti-theft feature provides an audible and visual alarm when unauthorized access to the vehicle is detected. When an intrusion is detected by any door or liftgate ajar switches, or the hood and trunk tamper switches it sends a ground signal to the GEM. When the GEM receives a signal indicating intrusion into the vehicle, the GEM supplies a ground signal to the horn control relay and the park lamps relay. The relay closes, supplying the power which activates the horn and the park lamps. The pulse stretcher module applies to wagons only. Due to the distance between the liftgate disarm switch and the GEM, the disarm switch signal is not present long enough for the GEM to recognize. The pulse stretcher module receives pulse input when switch is turned to unlock. The pulse stretcher module holds the pulse active for about 60ms so the GEM can recognize the signal and disarm the system. The perimeter anti-theft feature does not arm until 20 seconds elapses after locking the vehicle. The perimeter anti-theft device will disarm only when
  • unlock is pressed on the keyless entry remote transmitter.
  • keyless entry keypad code is entered.
  • door, luggage compartment lid or liftgate lock cylinder is turned to unlock.
  • ignition switch position changes to run or start.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Lock cylinder disarm switches
  • Hood switch
  • Luggage compartment lid switch
  • Loose or corroded connections
  • Generic electronic module (GEM)
  • Circuitry
Door Disarm Switch Removal and Installation
  1. Disconnect the battery ground cable. Refer to Section 414-01 .
  1. Remove the door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the watershield.
  1. Disconnect the latch lever from the door lock cylinder.
    1. Remove the E-clip.
    1. Disconnect the latch lever.
  1. NOTE: The door disarm switch can be installed in more than one position. Before removing the switch from the cylinder it may be necessary to mark the position of the switch in relation to the lock cylinder.
    Remove the door disarm switch.
    • Disconnect disarm switch electrical connector.
  1. NOTE: The door disarm switch can be installed in more than one position. Use the reference marks applied in the removal procedure to index the new door disarm switch to the lock cylinder.
Jan 24, 2011 | 2005 Mercury Sable
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
How do you reset an alarm for a 1994 chrysler new yorker
there is no manual reset other than locking and unlocking the passenger or driver door with a key. the alarm is also disarmed each time the ignition key is turn to run, if u are locked out and have tried these methods to disarm the security system them there is a problem and the dealer must scan the Body Control Module (BCM) to determine what that might be.
Sep 30, 2010 | 1994 Chrysler New Yorker
How do i remove the alarm off my 94 chrysler new yorker? it wont let me start car or turn off the alarm.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Is this a factory alarm? If this is the case you have to apply a negative pulse to the wire color. Light Green/Orange located at the Driver’s kick panel as soon you apply a negative pulse the alarm will be disarmed and if you want to keep disarmed for ever just hook a wire to this Light Green/Orange and connect it direct to ground this way will keep always the alarm in disarm mode
Jun 04, 2010 | Chrysler Vehicle Parts & Accessories
Disarm car alarm
Simply disconnect the power leads to the alarm...........sodeep
May 11, 2009 | Vehicle Parts & Accessories
I disarmed alarm to get in and led stayed on
sounds like alarm problem with brain under dash on drivers side u can remove fuses and not use or have replaced
Mar 27, 2009 | Vehicle Parts & Accessories
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
Vehicle Parts & Accessories Logo
1,110 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
