I can't find the ipod facility in TV menu of Soniq 16'' TV. Have connected the lead as decribed in the manual but can't find the ipod playing facility in the TV menu.
  • 2 more comments
  • judekessler Sep 13, 2009
    Hi Redhaze,
    I don't want to watch a video on my ipod I only want to listen to music through the TV.
    Judy
    I've only got a cable with two attachments - red and white (no yellow). Is that my problem?
    Do I need a cable with 3 jacks ie the yellow video jack, plugged into the TV or can I use the red and white audio jacks only.
    Thanks for clarifying that. I have attached the red and white jacks to the 'connect audio output of your AV device' as described in the manual. It's not working yet. The OSD menu list is as follows: Video, Audio,TV, Setup and Parental. I have tried each item on the menu list in the OSD but can't get the iPod to play using any of them. The remote has a button on it called iPod SWITCH which I have tried pressing in each item on the menu list. Which item on the menu list should I focus on? How does the iPod SWITCH button become active?
  • 10,594 Answers
Please select that AV input in TV where you hooked ipod cable and pree play button o ipod.
TV has no menu for ipod but will show ipod video files.
Thanks.
Posted on Sep 13, 2009
    Brigadier General:
  • 4,090 Answers
Judy the RED and WHITE plugs are for sound only match them to your TV AUDIO INPUT and all should work you CAN have AV channel or just the LOGO so there is no TV noise .You dont need to have a 3 plug cord
Please rate our help to keep the FREE service online++++Thankis for using FIXYA
  • 854 Answers
Here's how.
What You'll Need
In order to get your iPod connected properly to your TV, you'll need the following items on hand:
* A video-capable iPod. Any color will do.
* An iPod-compatible video. Load it onto your iPod through iTunes.
* An A/V cable. If you don't already have an eighth-inch-to-RCA cable, you can pick one up on eBay for five or six bucks shipped. Search for "camcorder A/V cable." Remember, you want a three-plug yellow/red/white RCA connection at one end and a three-banded eighth-inch (3.5mm) A/V plug at the other.
Figure 1. A camcorder A/V cable has a three-plug RCA connection at one end and a three-banded 1/8" plug at the other
Setting Up Your iPod Video Options
Setting up your iPod video options lets you control how you export video. The iPod Video Options screen selects how your iPod handles video file playback.
To open these settings, choose Videos -> Video Settings from your main iPod menu. This screen offers three settings: TV Out, TV Signal and Widescreen. Adjust to produce the video playback style you need.
Figure 2. Videos -> Video Settings controls the way your iPod plays back video file
TV Out
Whenever you play a video file, your iPod must make a choice. Video iPods either play video on the built-in screen or they transmit a video signal out of the microphone jack. They don't do both. The TV Out option controls which behavior occurs.
Use this setting to choose from:
* No. Playback remains on the iPod itself.
* Yes. A TV signal is produced.
* Ask. The iPod prompts you whenever you play a video file.
I always use the Ask option. Yes, it does add an extra step whenever I play a video file, but it gives me the flexibility to choose playback behavior on a case-by-case basis. I like that.
TV Signal
European and Australian television sets use a different signal standard than those used in America and Japan. If you live in the U.S., your TV works with the NTSC standard. European countries mostly use PAL. Make sure you've selected the correct signal for your country.
Widescreen
iPods can play back widescreen video, if only on exported video. The built-in screen uses a traditional 4:3 screen ratio, rather than widescreen's 16:9 proportions. Choose Yes to produce a widescreen signal, or No to export the traditional TV output.
  • redhaze89
    redhaze89 Sep 13, 2009
    You can use the same cable as showned above
I have a Soniq big screen TV. How do I disable the TV speakers in sound settings and make the sound settings go to my external amp? There is no option in the menu to allow me to do this.
Try your input where you change your hdmi there should be a window where yiur normal tv will still play under the window it may give you options to go external output speakers.i did this with my lg tv when i connected external home cinema. Good luck
Sep 18, 2017 | Televison & Video
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Code for UCR-7140 to Soniq TV
0458,0529,0376,0884,0932 are the codes to check with Soniq brand TVs. If you wish to get more codes, check this link.
Feb 09, 2013 | Televison & Video
Media Player Confusion
go to iPod setting> select USB connection to TV
May 09, 2010 | Toshiba 26C100U 26 in. TV
I have a 42" acoustics solution tv and connected a blue ray player through hdmi, I cannot get a full screen when watching a dvd and tv won't allow me to change screen size, it just stays at 16.9 and...
YOu should have option in the DVD you were watching..
When the menu plays you should have the option to switch it to 16:9 or 4:3, if this option doesnt have the menu, then you have to use the option from the TV, but this option doesnt work with the Scart lead, you should connect it throught the RCA cable to enable changing modes
Please leave me comment, if you need further assistance
Thanks for using Fixya
Please rate this solution
Rnj VinodKumar
Dec 15, 2009 | iLO LCT32HA36 Television
Need a hack code for region free on QV220LTi
how to get region codes for my tv/dvd/ipod combo as it will not play my american movies?
Sep 14, 2009 | Televison & Video
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
