Question about Poulan Garden
I have a 18 in poulan wildthing chainsaw p4018wm the pull rope was jamed so i took it apart and wound it back but a small black spring fell out gave no idea were it goes i need a dirgram
  • 124 Answers
What you have is the spring assist starter. This is a new style starter that does not engage with the flywheel in a direct basis as starters have don for the past 50 years. What happens is that you have two springs. One to recoil the rope and one to store energy to release to the flywheel in a sudden burst. If you do not like this type starter you should be able to buy the old style and replace it. Most of the parts list I have seen still show the old style starter. Check with a full service dealer in your area if you have one. If you can not find one in your area contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Posted on Sep 13, 2009
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
HOW DO YOUREMOVE THE SPROCKET
The P4018 has an out board sprocket, so to remove you need to remove the side cover nuts and take away the cover, the bar and the chain, there is then an e clip on the end of the crank, insert a suitable screw driver into the inner edge of this clip and gently pry off, take away the large backing washer, the sprocket will now just pull off the crank.
Jan 13, 2013 | Poulan P4018wm Wildthing Chainsaw Wild...
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The rope does not retract when the cord is pulle... how do I fix it
Has the cord been replaced? If so, when the old one broke, the spring will completely unwind. The trick is to rewind the spring first, attach the new cord and wind it around the spool while holding the spring tension. After the cord is wound, feed the end out through the cord port and test for good return (don't let go!!), then clamp the cord with locking pliers and affix the handle to the cord. Melting the cord ends helps keep the knots from pulling out. Hope this helps!
Jun 07, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cant remember how to put the spring back on the pull cord recoil
This reply is based on the following assumptions:
A Poulan PP2375LE (wildthing) Type 2
The starter recoil spring is unwound.
All components aer servicable
Poulan 2375LE Type 2 IPL
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Starter components and reassembly order are illustrated on the "Handle, Chassis & Bar Assembly" detail.
If the spring needs rewound this is how I do it, there are other methods.
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool.
This illustrates proper pretension and rope installation:
Smalleng.com (about 3.5 minutes long and worth watching the entire video)
http://www.youtube.com/watch?v=eRyy3MlsjVo
If yours is not a Type 2 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I hope this was helpful
Lou
Jan 29, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to replace starter rope and spring on the 14" poulan. What's the trick for getting the spring wound and installed back in the housing?
There should be a mount inside the casing and another one on the starter rope socket. Wind all but a foot or so of your pull rope onto the sprocket then mount the spring on the mount in the casing. Don't worry about winding the spring yet. After that attack the spring to the sprocket. There should be a notch cut in the edge of the sprocket. Lay the rope in the notch and then place the spocket back into the case. With the rope in the notch you can then start winding up the spring taking the twists out of the rope as you do it. Depending on the length of your rope you'll probably need 5 or 6 turns of the sprocket. Once you get it wound then position the notch where the pull rope exits the housing. Grap the rope handle and pull the excess rope until it is all in the sprocket or outside the case and no longer in the notch. There might be some retainers for the sprocket. I"m not that familiar with Poulan. Secure these if there are some and put the housing back onto the saw and you should be good to go.
Nov 21, 2009 | Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need help putting the metal spring back in. i
Hey if you look at poulan starter rope there is a solution posted for how to re-wrap the spring. ( it's actually pretty quick and easy to do ).
Jul 02, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Garden Logo
228 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
