Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator not working
Whirlpool washer model LSQ9544KQO Agotatgor Jumps and Makes some noise Is Not Moving The Clothes Aroundjnchoate@
  • 5,911 Answers
If the entire agitator is slipping, you probably have a loose agitator bolt that requires tightening. If its only the auger (upper portion of the agitator), you have worn agitator dogs that need to be replaced. The following link explains how to replace the dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number for the agitator dogs is included in the link provided, along with how to locate and tighten the agitator bolt if it was found to be loose. Do not overtighten the bolt as this can cause damage to the agitator and/or restrict its movement. Tighten until snug.
The dogs can be purchased at pcappliancerepair.com for about $5. For just a bit more you can use part number 285809 and purchase the entire cam replacement kit which includes the cam, the bearing and the dogs for about $8.
If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Sep 13, 2009
    President:
  • 1,136 Answers
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Clothes & sheets get wrapped in agitator and it makes a loud noise in my Whirlpool wtw4800xq1
Here is a video on how to change a part that could be part of the problem, the video shows how to remove the agitator so that you can remove the clothing that is jamming the machine, http://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Agitator-Repair-Kit/285809/470910?modelNumber=WTW4800XQ1&ss=a11b5d956381&mr=1
Jul 30, 2016 | Whirlpool Washing Machines
Ultimate Care II, Lsq9544kqo. Why does it tie clothes in knots?
some things need to be in a laundry sack when washed . one of those mesh net type bags
Oct 01, 2015 | Whirlpool Washing Machines
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Sep 23, 2009 | Whirlpool Washing Machines
Top load whirlpool washer model LSQ9544KQO leaking small amount
more likely from a hose........need lid off and a good torch
cheers
Aug 03, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Won't spin or agitate, makes grinding nois only.
Pick up a copy of the Nov."The family Handyman" magazine. Pg. 60 shows your problem and how to repair it. Most likely it's a broken coupling,
Oct 29, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
598 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
