Question about Nintendo DS Lite Console
Keeps redoing initial set-up
HELP-after putting in a new battery now my DS keeps taking me through the system settings and then tells me needs to restart to save settings, but after i restart it has me do it all over agian. Why is it not saving my settings
  • 8amg1 Dec 13, 2007
    I did that and it didn't work. Anyone else have any ideas.
  • gingerale Sep 19, 2008
    My daughter dropped it on the floor and, after that, it keeps asking for the settings, says it saves it but, upon restart - starts all over again.
    Problem Solver:
  • 8 Answers
Turn it on, then let the battery die completely, this will take a while but it may work, then charge it fully and see if it works, sometimes new batteries do that sorta thing
Posted on Dec 11, 2007
I can't get connected to Netflix. I keep getting error 51030
That sounds like a Nitendo Wii errorcode; assuming your using that to watch Netflix:
From the tech support website: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Error Code: 51030
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Click here for info on setting up your Wii: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
In other words; you Wii doesn't seem to be connected to your WiFi network anymore ...
Jun 29, 2014 | Netflix
Tip
How to reset Nintendo DS Lite.
Remove the cover for the battery compartment. At the back of the DS Lite, the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not cause a reset in the unit.
Put the battery pack back. Just line it up in the compartment and push it back into place.
Replace the cover. Replace with the screw.
Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
on Feb 12, 2010 | Computers & Internet
Unable to find access point. an internet connection is required. error code 51030.
  • you can visit this link for more info about your console pls rate me if this halp you thanks...
Jul 28, 2011 | Nintendo Wii Console
I have U verse and I am trying to watch netflix over the wireless network. I get code 51030. How can I make this work...?
Error Code: 51030
Source:http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
May 08, 2011 | Nintendo Wii Console
Im trying to connect to the internet and it says error code 051030 wat do i do
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051030&system=Wii&locale=lang
May 06, 2011 | Nintendo Wii Console
Error code 51030 cnnnot connect to wireless ssid code was changed so WII not connecting
Hii Sir
May 01, 2011 | Nintendo Wii Console
How to reset your nintendo DS
Hi. Here's the procedure on how to reset the console. Take note that if you are going to do this procedure this will erase all of the data saved on the system and restore the unit to its original factory settings.
Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit, and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
  • 2 Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
  • 3 Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not reset the unit.
  • 4 Put the battery pack back into the unit. Just line it up in the compartment and push it back into place.
  • 5 Replace the cover. Secure the cover back into place with the screw.
  • 6 Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all-new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
  • Sep 12, 2010 | Nintendo DS Console
    How do you restart nintendogs
    No No No! Bad Silver! Before You See The Nintendo Sign (It may be after) Press and Hold A +B + X + Y + L Trigger + R Trigger and that's all. Taking Apart Your DS gives you a 99% Chance of epic fail. -_-
    Feb 12, 2010 | Nintendo DS Lite
    DS Keeps telling me to put the system settings
    If you go to the Settings option as you obviously have, try to go into the Start-up options and click on the Arrow leading into a box.... this will take you to manual mode or Auto mode. If you chose Auto mode it will just start up the game as you put the card in. If you want to change it... take the game out, start it up and you will have the option of changing it back to manual mode or changing your settings etc. Make sure you hit confirm with all the options you change.
    Mar 11, 2008 | Nintendo DS Lite Console
    Please help with nintendo ds lite
    Try using the original battery.
    Dec 19, 2007 | Nintendo DS Lite Console
    Nintendo DS Lite Console Logo
    213 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Zhenya Ogorodnikov
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
