Question about Garden
The fuel line is rotted and the fuel filter fell off (along with parts of the rotted fuel line). How is this best repaired?
  • Rick Sep 13, 2009
    A McCulloch model 3818AV
  • Richard Bleau
    Richard Bleau May 11, 2010
    what type of saw do you have{ name and model #
    Guru:
  • 597 Answers
Take a piece of the old hose to a parts store. Buy new line and cut to the same length as the old line and replace it.
Posted on Sep 13, 2009
  • 28 Answers
You can try to match the fuel hose with a replacement piece from an auto supply or you can order a new part. I think you will find this site helpfull
http://www.oscar-wilson.com/MANUALS/MCCULLOCH/211318-03.PDF
Fuel pump works but not putting fuel to motor in 2000 s10 2.2
I take your statement "fuel pump works" to mean it is completely in good working order. So either the demand for fuel is not being properly relayed or there is a blockage between the fuel pump and the engine. The fuel filter is often along the line from the pump to the engine, if it is not part of the pump itself. Your saying the pump is fine suggests the filter is along the line. The fuel filter would be the simplest and least expensive place to start. As others have said on various questions, I too highly recommend getting a repair manual for your truck, e.g. Hayes, etc.
Feb 13, 2017 | Cars & Trucks
Runs terrible misses loss of power and reading p0174 code.
P0174 means that you have to much oxygen in the exaust system. When your car is running your computer sets the air/fuel mixture for you to run at its best perfomance. Most causes for this propblems are; 1. MAF Mass Air Flow Sensor. 2. worn out/dry rotted/ leaky vacuum lines 3. posible EGR vavle but not real common & 4. low fuel pressue. You can clean the MAF with electrical parts cleaner but don't touch the wires and stuff and I would only use elecrical parts cleaner. It should be located in the air duct. Next I would check all my vaccuum lines including the EGR valve for dry rot and the such. The finally you might want to change your fuel filter if it hasn't been done in awhile as well as if posible check your fuel pressure. Disconnect your battery when you are taking the MAF off. I hope this helps and good luck.
Jan 29, 2011 | 2003 Ford Expedition
I'm trying to replace the fuel lines on the primer button of a small McCullough chain saw. The old ones had dry-rotted and fell off, and I couldn't determine which line goes where. My first configuration...
The primer is just a small pump--it is supposed to draw fresh fuel through the carburetor and expel it back into the tank. There are also just two lines on the carburetor--the upper one should go straight to the fuel tank and filter, the other goes to the intake side of the pump. Just pick a port of the primer (remove the other line for the moment), and try to pump fuel into the bulb (make sure the bulb is not decayed as well)--it should fill with fuel if you have the correct connection--if not, just place the line from the carburetor on the other primer port and try to pump again. If still no fuel, something is plugged in the carburetor or the fuel filter. Hope this helps!
Nov 10, 2010 | McCulloch 16" Electric Chain Saw 35 HP
I have to replace rotted gas lines for a 99 sunfire.There are three lines that look to be two different sizes, Would you know what these are?
The main fuel line that goes to fuel filter is 3/8. The vent line & evap line are 5/16. Some parts of those lines reduce to 1/4 near fittings.
Sep 24, 2010 | 1999 Pontiac Sunfire
RE: craftsman weed wacker The weedwacker will start but not continue running; fuel is fresh so I think it's either air or fuel filter. Need info on how to change filters.
The air filter is a piece of cake... it is inside the middle cover which comes right off....The fuel filter is a different animal and is located IN the fuel tank at the end of the smaller diameter fuel line which comes out of the tank and goes directly to the body of the carburetor...your problem could be something else entirely though...like worn carb parts...partially clogged muffler and/or arrestor screen or port. These engine produce a by-product of carbon because of the amount of oil they burn along with the gas. It's good that it at least starts but I am leaning towards a problem with fuel delivery here. Drain the fuel tank... Look inside it and check condition of fuel filter...sometimes they break/rot off of the fuel line in the tank and the fuel lines should ALL be replaced at that point.
Jul 08, 2010 | Craftsman Garden
I have a 1994 Gran Marquis. Fuel lines are rotting and leaking
Just get a piece of the rotting fuel line so that you will be assured of getting the right size. Take it to a shop that sells car accessories, and ask them for enough to do your car. Also get new clamps. Start at the fuel tank, undo the clamp, pull off the old hose , put on the new one, do up the new clamp, and then just follow the old hose along, replacing it with the new one as you go. At the far end. do the same... undo the old clamp, put the new hose and clamp on. But I forgot to tell you about the fuel filter. Replace this while you are doing this job.
Feb 23, 2010 | 1994 Mercury Grand Marquis
My homelite leaf blower UT # UT08023B is running badly all of a sudden. when i pull the trigger to get it to full speed, it acts like it doesn't want to get to full speed only about half speed and it seems...
Its a fuel delivery problem. Its running lean.
Check the fuel line in the tank to see if the filter fell off. If the filter is loose in the tank than the best way to repair is to replace the fuel line. Also the diaghrams in the carb are dry or the screen is clogged. Lastly, if the fuel lines are not rotted and the screen in the carb is clear and everything is in proper working order then you can adjust the carb ( if it has adjustments). Start by turning the low speed needle out ( counterclockwise) 1/2 turn.
Nov 20, 2009 | Homelite Garden
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
Need digram to install fuel lines
First, you sould have one with a filter in the tank going to carb. Next run one from tank to primer bulb and from one from primer bulb to carb.
May 18, 2009 | Garden
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
