Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a white lawn tractor and i just change the battery and the spark plug and it wont start . I also have current to my switch to start but no current to the starter . Could you solve this.
  • 138 Answers
Do you have power from the switch to the starter solenoid ? What you should have is a battery lead going to the starter relay / solenoid. a battery lead coming from the relay / solenoid to the starter and a 12 or 14 gauge wire coming from the switch to the relay solenoid. Depending on the age of the machine this wire may actually go direct to the solenoid or it may have to go through a couple of safety switches. the first thing I would check is make sure you have power coming out of the starter switch to the start circuit. The terminal on the switch is usually marked with an s for starter / solenoid. If you have power coming out from here then trace this wire to either a safety switch or relay solenoid, keep checking for 12 vdc until you dont have power and you will either find the problem or the bad part... hope this helps you
Posted on Sep 13, 2009
With key my riding lawn mower does not start, not even crank. Nothing happened.
Are you positive that the battery is fully charged? If so check for current reaching the starter motor. If current is there then it appears that the starter motor is no good. If no current reaches motor it is possible the ignition switch is no good.
Aug 27, 2015 | Craftsman Garden
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman lawn tractor 42in w/briggs 22hp -low power up hill and cutting
white smoke is more than likely a water issue. Oil usually has a bluish tinge to it but is some cases, it could be white. Drain the gas a fill with fresh to try and eliminate the possibility of water in the gas. Watch the oil level to see if it changes after using the mower. it may take a few times but if it is burning oil, the spark plug will look "wet" and oil soaked, with possible black soot type build up.
Aug 13, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My lawn tractor won't start no spark an I have aready replaced the electrical control circuit board. It is a LX277 lawn tractor year 2000 I think. After I replaced the circuit board It still did't start I...
May be the coil is bad. have you checked the spark plug? If there is gas and spark then it will have to start.check the circuit breaker points. is there current in the cb points?
Sep 10, 2009 | John Deere Garden
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cant get my lawn tractor to start
IT COULD BE IGNITION SWITCH IS BAD, I REPLACED ONE ON A CRAFTSMAN THAT DID THIS,BUT ALSO COULD BE A SAFETY SWITCH IS NOT CLOSED PREVENTING STARTER FROM OPERATING,---WITH THE IGNITION SET TO ON CROSS THE TERMINALS ON SOLENOID AND SEE IF IT STARTS THE TRACTOR RUNNING, IF IT FAILS TO RUN ITS PROBALY THE IGNITION SWITCH THEN.
Apr 09, 2009 | Briggs & Stratton Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
210 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
