KS4102: Remote volume buttons won't work . Button is stuck down for the "lower volume" so I am only able to use "high volume" which is too loud for comfortable listening. Do I need replacement remote, and if yes, where do I order one?
    Novelist:
  • 133 Answers
You can disassemble and clean the remote, this might help.
Clean the rubber keypad with ethyl alcohol and cottonwool, also clean the contact tabs on the rubber keypad and on the circuit board (don't rub the contacts too hard when you clean them, you don't want to damage the conductive coating).
Also clean well the housing, especially the holes on the housing where the rubber buttons protrude.
The holes (and the rubber buttons) get dirty with use and this often causes the buttons to get stuck.
I had to "repair" several remotes with stuck buttons, and simple cleaning did the trick.
I hope you can get it fixed...
Regards
3rq8 (Triarcuate)
Posted on Sep 13, 2009
Volume will not change on my trio v2 plus
In the playing music mode, press the center button one time and then hit either the button to the right to raise the volume or the button to the left to lower the volume.If you hold down the center button it gives you other options.
May 09, 2012 | Mach Speed Audio Players & Recorders
The volume up button on the remote and the tv are not working at all and the volume down button works but it does not turn the volume down instead it cycles through what seems to be different modes of...
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
Jul 15, 2011 | Samsung CXD1342 13 in. Combo
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Jun 09, 2011 | Televison & Video
The volume stays on high. I can lower it but, after I release the button the volume goes back to high.
I have the same problem with KV-20-FV-300. My remote stopped working and when I adjusted the volume manually, it goes to high and when it adjust it back down, it goes high again. I'm able to get the sound to stabilize by getting the volume to where I want it, and then pushing the up and down volume buttons at the same time. I'm still searching for a permanant solution though.
Mar 20, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
No volume without holding remote button
The volume on either on your Remote or Tv is stuck down. This can be caused by spilling Liquid onto the remote (we all do it) you can test which one it is.
take the battery's out of the remote and turn the volume up via the Tv volume button on the telly. If this stays at the required Volume Then this means that the - volume button is stuck down on the remote. Try and clean it with something like a baby wipe or something similar (not a sopping wet cloth) If this does not work then you may need a new remote.
Hope this Helps
Cheers
Little Dish Fitter
Sep 24, 2009 | Televison & Video
My volume button goes all the way up to the max and stays there and sometimes my mute won't work how do i fix the problem
It looks as if your volume up button is stuck, either on the TVs manual buttons or the volume up button from the remote. To check if it's the remote, put the remote away from the TV, either in a drawer or take the batteries out. If the same check the Volume up button on the TV, it may be pressed down & stuck in this position. If this is ok most likely the volume button will be at fault & need replaced.
Jul 13, 2009 | GE 31GT660 TV
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Volume Control
check the up volume button on the set. it sounds like it is stuck in the on position. You can open the back and disconnect the wire harness to the control buttons. This will verify if the volume up button is the problem.
Feb 11, 2009 | Akai LCT3215/26 32 in. LCD Television
My RCA 32" TV
If volume shows erratically behaviour do the following:
  • Take batteries out from remote and check if it is a remote problem.
  • Try pressing and playing volume buttond on TV, see if it can be a button.
  • If it is a button remove front panel and clean button contacts with circuit cleaning solution.
  • If all the above did not work, it is either a faultycontrol panel or a faulty audio pcb on your tv. Them both must betested (control panel it is an easy test if you know how to use amultimeter)
If you need replacement parts enter model here
If you need to call a technician you can ring the number listed on your owner manual
Sep 11, 2008 | Televison & Video
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
