Question about Jenn-Air http://www.jennair.com/catalog/product.jsp parentCat=2&cat=17&prod=155 Electric Range
I have a JES9800AAW Jennair oven that vents thru the floor. I noticed the vent van was running when I had not run the oven. Yesterday and today the Fault code F1-1 comes on even when I use the electric burners. What does these mean? The people at Jenn air had no answer and told me to call a repairman.
Eddie Rentas
  • 59 Answers
SOURCE: downdraft vent on jenn air cooktop
Hello
Just get a dryer vent tube the flexible ones and some aluminum tape and that will do it, I had the same problem and thats how the gas company told me to do it and it works excelent.
Eddie Rentas
Tupper Lake NY
Posted on Jul 26, 2008
SOURCE: outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Posted on Dec 09, 2008
philbran
  • 242 Answers
SOURCE: How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Posted on Apr 10, 2009
VWdan
  • 114 Answers
SOURCE: ac will not blow thru ac vents, only thru defrost vents.
if vent doors are operated by vacuum check for loose or broken vacuum hoses in the engine compartment , or check the fuse box for any ac/heat fuses if it is a electricaly controoled system
Posted on May 04, 2009
SOURCE: trunk leaking water thru vents in the side walls
Easy to fix. Remove trunk liner or peel back on passenger side. Squeeze tabs that hold in the vent housing and push out. You have to loosen the bumper panel over in the wheel well area. This is just two bolts that take a 10 mm wrench and a plastic body clip. Remove vent from outside of car. Take off old gasket and throw away. Clean vent and metal around where vent goes completely with lacquer thinner. Use a product such as Lexel to caulk around where gasket used to be. Be liberal with caulking, it all covers. Reinstall vent and other parts in reverse order. Poblem solved. One hour to do and no special tools required.
Posted on May 10, 2009
HELP, with my montana rear air
You have a mode door motor that has failed and is stuck half way so air is going to directions
May 06, 2014 | Pontiac Montana Cars & Trucks
When I start my bike, after 30 seconds fuel backs up in the fuel vent tubes and dumps out on the floor. It backs ups thru the air intake, fills the canister on the end of the vent tube, and over flows...
Float is sticking in one or more carbs. To narrow which one it is, drain each carb seperately,measuring the feul in each carb. The one with the most is the one the float is sticking on. Be sure that the top vent lines are not blocked or colapsed.
Nov 02, 2010 | 2002 Yamaha YZF 600 R thunder cat
01 dodge 2500 v8. Air conditioner started out strong, blowing cold air..temporarily would start blowing warm and then back to ice cold...Noticed when stopping and turning corners a hissing noise coming...
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
Have a good one!
Aug 13, 2010 | 2001 Dodge Ram 2500 Truck
The blower will not change from the upper vents to the floor vents. The blower, AC and heat all works well but cannot cet the vent source to switch from the upper vents to the floor
sounds like you lost vacuum there is a vacuum line running from engine thru firewall that supplies vacuum make sure it,s not off or broken hope this helps this is my last post on this website they do not live up to thier expectations so i will be posting @ another website in future
Mar 20, 2010 | 2003 Dodge Dakota Club Cab
Whirlpool microwave oven mh7155xmb0 not venting
Possibly a bird built a nest (swallows) in or on the roof vent. Make sure the fan turns freely when off. Check the vent tube that goes up to the roof--if flex-tubing, it may have collapsed and pinched off the air flow (it may be too long). Make sure that a one-way valve which should be near the exit of the hood is free to move when air flow pushes on it. This valve is supposed to prevent back-flow of air into the house. Hope this helps!
Mar 09, 2009 | Whirlpool MH7155XM Microwave Oven
No air flow from defrost vent on my van.
Could be a vaccum line leaking not changing the vent flap to defrost
Jan 10, 2009 | 2001 Oldsmobile Silhouette
No air flow through 4 top rear vents
Don't worry, it's designed that way. The owner's manual is pretty unclear about this. But the heated air only comes out the floor vents underneath the front seats and the "heat vents" at the forward and side of the rear A/C compartment near the floor. The cooled or vent air flows from the overhead vents.
Nov 28, 2008 | 2004 Honda Odyssey
2001 ASTRO VAN AIR CONDITIONING
i suspect the vents are controlled by vacuum and are not opening due to a vacuum leak.
Robert
Sep 01, 2008 | 2000 Chevrolet Astro
Jenn-Air http://www.jennair.com/catalog/product.jsp parentCat=2&cat=17&prod=155 Electric Range Logo
91 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
