Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will not drain
Overfilled my washer w/ towels/sheets. it shook and will not drain i try to restart the cycle and it will resume a spin like what is done during cleaning when it is full of water but when it gets to the part of the cycle where it is to drain, it stops.
  • Whirlpool Master
  • 8,220 Answers
FYI: The lid must be closed for spin on older washer. It must be closed for wash and spin on newer ones. The lid has a striker in it that pushes against the lid switch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. The end that the harness plugs into has 3 holes. As you can see above the lid switch has 3 wires. 2 live wires and one green ground. You can jump the washer out using a horseshoe shaped wire or equivilent. Newer models have the ground wire on one end. Not good! Look for that before attempting to jump it out. At any rate their are 3 wires. One of them is always green and always mounted to the frame. The other 2 are live. You can jump them to magically make that puppy spin and pump. Not recommended to leave it that way. For testing purposes only. Some repair pix with manuals.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 13, 2009
Seriously need help!!!
take off the bottom panel and look inside the cavity on the sidewall, there should be a plastic pouch stuck there, inside will be what we call a "tech sheet". it will tell what each error code means. i suspect that either the "coin trap" [from the tub to the pump] is plugged or there is something stuck in the pump. if the drain system is not working, the control board will not cycle to spin. it's kinda messy so lay down a lot of towels
Sep 24, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer not spinning, nor draining
check the coupling/transmission.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore Washing Machines
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
F/H code continues
u have to go with a good technision
Aug 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet's interupted cycle won't restart
unplug, let sit for 2 min, replug and try to put into drain/spin cycle
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Jan 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
