Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Screen irregularities after mounting TV on the wall
We mounted our Vizio plasma TV on the wall today which necessitated unplgging and replugging in the cables. Now we are seeing some fleeting irregularities (picture quality) when watching TV. When moving the TV from the factory stand to mounting on the wall, the unit was not jarred, dropped, etc. Was working just fine before this. Any suggestions would be appreciated.
SOURCE: moving line through plasma and LCD TV's
This is a very common Ground loop problem. The quick cure is to put a 2 prong to 3 prong adapter on the plugs which effectivly removes the ground from the circuit and stops your lines. Have fixed over a hundred TV's since the 60's that way.
Posted on Oct 04, 2007
SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20.  20 is the length that I used and it works well.  You could also use 25 (which is a little longer) if you would like.
It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
Posted on Oct 11, 2007
phongnv
  • 56 Answers
SOURCE: HELP PLEASE Vizio Plasma tv broken again - possible driver board?
This could cause by the power supply or the mainboard.
- If the LED stay Green when you turn on the TV. But you can not turn it off, in this case the main board has failed. Replace the mainboard will fix the problem.
- If the LED light always stay at Orange, you can not turn on of off. In this case the mainboard also has failed.
- If you turn on the TV you will hear the power supply click on the LED is green then it click off the light turn Orange. In this case the power supply has failed.
Which boards did the repair shop replace?
Hope this will help.
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
  • 7 Answers
SOURCE: Vizio P42HDe Plasma TV - Audio, but no picture
check the backlight inverter and the Y-sus board the one to your left. if those are fine check the bottom right buffer board
Posted on Apr 20, 2009
Is there a special bracket to mount the 50 inch D series vizio to the wall?
Many aftermarket mounting brackets are virtually universal in application provided your 50-inch Vizio TV can meet the size and weight limitations stated.
Nov 29, 2014 | Vizio VP504F 50-inch 1080P Plasma TV...
Tv won't come on tried all the trouble shooting ideas in book but nada
hi if you brought the tv in november might best to get in contact where you got it from ask them to send a tech out, you won't have to pay as it should be covered by the warranty good luck
regards
shaun
Jan 23, 2014 | Universal 40-42 Inch Flat Screen Panel...
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
CAN YOU PLIZ HELP ME FIX MY TV
Press the AV button on the remote control. If it do not help you, make it a hard reset.
May 28, 2013 | Universal 40-42 Inch Flat Screen Panel...
Where can I buy a wall mount for the visio 22" flat screen I bought today
hello, any electronic retail store, bestbuy has two or three models that will easily handle your new vizio tv, make sure you get one that you do not have to modify(cut or end up buying extra hardware) to make it fit the mounting area(rear) of your tv. Take the TV with you or get good measurements of the mointing area to avoid problems when installing.
Dec 01, 2010 | Vizio Televison & Video
How do I wall mount my tv
Please check the bellow links related to your issue :-
http://www.practical-home-theater-guide.com/plasma-TV-wall-mount.html
http://www.wikihow.com/Wall-Mount-a-Plasma
http://www.ehow.com/how_4796104_install-plasma-tv-wall.html
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Televison & Video
Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
Nov 13, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
18 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
