Question about Nilfisk Family Vac Bagged Canister Vacuum
Nilfisk Family Vacuum - Strong Awful Odor
I have a NIlfisk vacuum that started to emit an awful bacteria like odor. I know that I need to replace the filter but am not sure if I need to replace the hepa filter or the "main filter" on certain websites.
  • 430 Answers
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Posted on Sep 13, 2009
Nilfisk hoover will not switch on
Start with the basics, check for a reset button on the motor housing, make sure the circuit that the appliance is plugged into not a gfi circuit
thats been tripped. Keep in mind that when working with any electrical
-know your kimits!
Aug 16, 2014 | Nilfisk Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
Motor housing is hot
This model has 2 side filters, check and clean those. Be aware that this is a quick clean vac, not to be used for extended periods of time to replace a full size upright. clean the inside filter in the dirt cup.
Apr 16, 2010 | Hoover S2220 Flair Bagless Upright Vacuum
Need directions on how to remove old cotton filter and install new one and same for HEPA filter on Nilfisk GM/GS 80.
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=Nilfisk+GM%2FGS+80+instruction+manual
Jim
Dec 03, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
How can we avoid the odor that we usually have with other vac exhausts? will cleaning the filters as suggested really keep that from happening?
Bagless vacuums have a real problem with bacterial growth. That is what produces the odor you are smelling. Wash the cup in an enzyme and the filters too if they are the washable type. Make sure everything is dry before you reassemble the vac. Then turn on the vac and pull the hose out like you would be using the tools. Holding the hose end that has the suction, spray a small burst of Lysol Spray into the hose opening so the vacuum "sucks" the Lysol through it's interior. This will kill the bacteria in the hose and the plastic housing of your vacuum. Usually 3 bursts works fine. If you spray too much and get your machine "wet" with the lysol you could damage your motor so small bursts are better than a long spraying action
Oct 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Nilfisk GD930 vacuum-can't find replacement brush
Hello mddamus,
Try this link to a Nilfisk supplier, speak with a rep and they should be able to identify exactly what you need and provide that part for you.. http://www.nilfiskcfm.com/ProductAcc.aspx?m=15
Regards,
Rick
Dec 06, 2008 | Nilfisk GD 930 Canister Vacuum
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Vacuum cleaner smell
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=528723
Posted by lcw1 on Apr 20, 2008
Our Hoover Windtunnel has recently started emitting a bad odor when we use it. We recently bought a new house, and the previous owners had dogs, but the carpet was professionally cleaned before we moved in. I have replaced all of the filters and belts to no avail. At this point, I have to remove and rinse off all of the filters after every time I use the vacuum to prevent stinking up the entire house. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover U6616-900 WindTunnel Bagless...
Nilfisk Family Vac Bagged Canister Vacuum Logo
407 people viewed this question
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
