Question about Solid Audio F15D 1-Channel Amplifier Car Audio Amplifier
Bridging a f15d mono block from solid audio witch outputs do i use
    Guru:
  • 1,326 Answers
Normally right positive and left neg. Your amp should have indicators on the terminals. Of the four you should have a separate + and - for each channel. This tells you which channel is for pos, and which is for neg. If no markings switch for each one left pos/right neg or right pos/left neg. It will only work on one way.
Posted on Sep 13, 2009
How do you bridge a JBL GTO7001 amp
JBL do not suggest bridging this amplifier. As it is a mono block, the "stereo outputs that are on the amplifier go to the same contacts inside", so effectively both Left and Right outputs are the same, (like using a headphone splitter.) this is designed for ease of use when installing more than one subwoofer. if you run your sub/s at two ohms you will be able to get the full 700WRMS out of this unit.
so in effect if you "bridge" this amplifier it will not be any different if you hadn't. Bridging is designed for TWO or more channel amplifiers to increase the power going to the speakers, but not needed in a mono block amplifier.
I hope i have helped you with your problem and please dont forget to rate my solution.
cheers
Jan 14, 2011 | JBL GTO7001 Car Amp
Amplifier shuts down after 30 secs of loud playing
Could be a couple of different things. It's more than likely the wiring between woofer and amp is the problem. Check the Ohm load on the woofer to make sure it's compatiable with the amp. If your woofer is wired at 1 Ohm, and the amp can only take a 2 Ohm load, it would cause this problem. Also, are you having any issues with the voltage of your car? If your car's current electrical system can't keep up with your higher power demands, then it might also casuse this problem. I would check the wires first.
May 27, 2010 | Solid Audio F15D 1-Channel Amplifier Car...
Wiring diagram for sony xplod amp and how to bridge one
if you have the model number handy i can tell you
but most sonys are marked like this ..
+12v goes directly to the + termanl on the battry
GND goes to a solid metal object on the car (ground)
REM remote turnon goes to the remote turn on from your headunit
unbridged speaker outputs
+L positve left speaker
-L negative left speaker
+R positive right speaker
-R negative right speaker
ok to bridge a amp (must be capabul of doing so) look for a mono switch and set to mono ..
then take the +L channel put it to your subs + and take the -R channel and put it to the - of your sub
also set the cross over switch to LPF if your running bridged for a sub
if that is a bit hard to understand msg back with the model number of the amp and i can get u the orignal manual for the wireing diagram
hope that helps
Jan 26, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
Bridging outputs on JBL BP300
Hello paulnkate,
The BP300.1 is a mono (1 channel) amp. You cannot bridge a mono amp. Bridging is a method of combining the outputs of 2 or more channels of a multichannel amp into a single mono load. On your amp you would connect a single sub to one of the +'s and one of the -'s (either one is OK, they are connected internally). The other pair of terminals is just for convenience, making it easier to connect, if you want to power 2 subs.
Hope this helps.
Jul 20, 2009 | JBL BP300.1 PowerValve Series Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    L7 wiring options
    yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
    Aug 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
    Is that ok to do mono on Thump TA1001
    yes, it is a bridgable amplifier, if that is what you are talking about. Look at the speaker output terminal and it should have markings on it for stereo output and it will have a line between the 2 terminals to use for bridging it. When you bridge an amplifier it is mono. There may also be a switch on the amp for stereo or bridged. Put that switch in the bridged mode. Connect one speaker to the speaker output and you have your bridged mono amplifier. If you plan on using 2 woofers, it is better and safer to use it in stereo mode with one speaker on each channel.
    Let me know if you need any more help,
    Dave
    Aug 08, 2008 | Thump TA1001 Car Audio Amplifier
    Wiring Diagram
    i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
    Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
    Alpine PDX-4.100 3ch operation
    use channel 1 and 2 as normal, use the positive from channel 3 and the negative for channel 4 as mono 1ch, your bridged output on the mono chan should be around 200watts at 4ohms.
    Nov 25, 2007 | Alpine PDX-4.100 Car Audio Amplifier
    Car Audio & Video Logo
    168 people viewed this question
    Top Solid Audio Car Audio & Video Experts
    xxxxxx xxx
    Are you a Solid Audio Car Audio and Video Expert? Answer questions, earn points and help others
