Question about Garden
I have compressor with clutch that work with coil 24vDC. How can I make it work with 12vdc?
  • ayman0579 Sep 13, 2009
    This is expensive.
  • ayman0579 Sep 14, 2009
    not acceptable
  • 291 Answers
Sorry to say that it won't work that way. If you had a 12V coil that you wanted to run on 24V, you could use a resistor of the right size and wattage to drop th 24V down to 12V, but if your coil needs 24V, 12V won't be able to run it. If it were AC, you could add a transformer, but they won't work with DC!
Posted on Sep 13, 2009
  • 284 Answers
You will need to find a step-up dc-dc 12v-24v converter.
Is it just the coil that needs 24v?
What runs the compressor?
It depends on how much power you need.
You may be able to find a 12v - 24v DC-DC step up converter but they don't provide a lot of amps.
Again if it is just the coil you need to power to engage the clutch you could get a couple of small batteries and hook them up in series until you get to 24v. They might last for ages before you need to replace them.
Hope this helps.
04 navigator is blowing ac fuse 11, ac coil shorted, 3 different coils, can ac compress short the coils
How did you hook up the inline fuse to compressor and ground to compress ? Ground what ? Right at the clutch coil ? You have to be hooking it up wrong . The compressor can't cause the clutch coil to short or blow the fuse , even if the compressor were seized up . An before that would have the serpentine belt would burn up , squealing noise. applying B+ voltage in the relay socket ,pin 30 to pin 87 will engage the compressor clutch . If the fuse blows the wiring from the relay to the compressor clutch is shorted to ground . Look for rubbed through wiring harness .
Jul 14, 2017 | Ford Cars & Trucks
Can l use a garmin sat nav on 24volt
Garmin GPS products operate on +5VDC and require an adapter to convert +12VDC to +5VDC. The internal battery is 3.7VDC and is charged by the +5VDC.
If you want to use +24VDC, you will need to find an adapter that converts +24VDC to +5VDC @ 1AMP and has the right connector to mate with the unit. Connecting +24VDC directly to the unit will damage the GPS.
Some motorcyclists connect the GPS directly to the +12VDC battery and damage the GPS.
Jun 03, 2016 | Garmin GPS
My a/c is not working in my 2008 Suzuki forenza.
engine running
A/C on, a/c lamp glowing
fan on HIGH
the compressor clutch ,engages. (belt not missing or loose)
the compressor shaft spins very fast. near engine speed.
if it does, the loop has issues.
if not, the A/C AMP logic, module or the hi/lo freon swtich is open
the AMP, protects the loop and driver.
  1. the amp cuts the compressor, 6 ways, (about)
  2. evap freeze up
  3. a/c loop freon too low or high (that switch )
  4. engine overload.
  5. driving WOT, can cut A/c (wide open throttle) driver protection
  6. engine overheated.
if the clutch is dead. see if there is 12vdc across the clutch
yes, the coil in the clutch is open , OHMS= reads_ infinity
no.. the AMP as dropped off the A./C on purpose
we then check all inputs to the AMPA
i do the hi/lo switch first
all this is covered, in the FSM , HVAC chapter, not a secret at all.
alldata.com
suzuki pit stop plus
Sep 07, 2014 | 2008 Suzuki Forenza
What causes the air conditioner unit to screech
the compressor is seized.
key off.
a/c belt off.
apply power 12vdc to the clutch, the clutch is not enabled.
then buy hand, again engine off. turn the a/c pulley buy
hand, i bet you cant, and is called Seized.
this method works for all parts, on all belts that might seize.
(only a/c needs the clutch active to feel it)
it is possible the clutch bearing is siezed.
that can be fell with not applying 12vdc it s coil.
Aug 09, 2014 | Suzuki XL7 Cars & Trucks
WHY MY IZUSU AIRCONDITION COMPRESSOR WILL NOT WORK AUTOMATIC
so the A/C is on , blower on and blowing
and the compressor clutch drops out?
the shaft on the compressor stalls? and pulley is fast.
that means the A/C AMP logic module sees errors.
or the hi/low pressure switch is open (12vdc on both sides is good)
Jul 14, 2014 | Isuzu Pickup Cars & Trucks
2008 honda accord air will not work ,has freon ,relay works but compressor will not kick on.
#1 top A/C post here ever. bravo that.
this is caused by by the AC brain.
(location varies by year, and country)
A/C brain discrete, cira 90s
to after 2007 , they moved the brain, now pure software inside
the ECU or BCM , on most cars.
it really dont matter much where it is until you get to back probe the bugger. right?
so , here is the reasons for A/C clutch dead.
1:clutch bad, apply 12v to it see if it works (wires discon, please)
do so for on 1second, so as not damage system.
check for coil ohms near 1ohm. at clutch.
infinity is bad coil.
OR do :
1b" 12v to coil AC on? any volt meter works. 11 to 15v typical.
13.3 to 14.7 running engine typical.
yes, clutch dead.
2: 12v not at coil of clutch bad relay.
3: relay coil not energized.
3a: power to relay not on coil, if yes, bad relay .
3b: relay coil dead. no power. the brain has it shut down!
4: the brain, stops the AC for all these reasons
simple answer , inputs wrong.
full answer:
a: too low freon pressure, in truth or sensor fibbing
b: too high freon pressure, same, reasons.
c: ENGINE over load, (pulling trailer or going WOT )
d: engine overheat. (ecu say so or AC has its own sensor saying so, RTM.
e: Evap core (the cold core in dash) has frozen over to a ice brick. (a freeze sensor is there) caused by stuck open expansion valve. in core.
f: no power to AC brain, 90s cars. or missing ground,
g: AC not on, or brain can not see fan going, usual the is just
the 12vdc to fan missing. or the wire fell off.
some cars have all this, my 96 does.
on newer cars the ECU can shut the AC down for many reasons.
most are related to safety to the driver, or Compressor.
for what reasons, only the FSM answers that , and varies
by year, engine type, model and country sold.
if in usa , you didnt say. then alldata dot com has these facts
and more , under section called HVAC.
The brain will not allow you to burn up the compressor or worse.
it tries very hard at that. even as old as 1991 cars. (some)
today all.
Oct 12, 2013 | 2008 Honda Accord 2.0i-VTEC
No power when television is turned on
1) test the outlet box and plug a desk lamp if work, if does the circuit is o.k if NOT reset the c.breaker from your home
2) test the power cord for open or break
3) see for a blown fuse inside and replace, or c.breaker tripped reset.
4) test for short in transformer+coil+filter+diode+rectifier and ground chassin.
5) test the Horizontal output for +125vdc +HVREC+FLYBACK+vertical output for 80vdc+all they go to the CRT. measure the color circuite +12vdc+other circuite+12vdc+audio 24vdc. see the block diagram oTHERWISE you must to the repair shop TV
God bless you
Jul 31, 2012 | Zenith Televison & Video
Coil on a/c compressor
If you are talking about the part behind the pulley on the compressor, its part of the clutch assembly.
You get the pulley and coil as a kit which bolts to the shaft.
Check the online auto parts stores for ac clutch.
Jul 19, 2012 | Dodge Cars & Trucks
You do understand that the compressor cycles on and off as needed to maintain system pressure?? Check and see if the clutch closing coil has 12 volts to it at the connector when it stops, if it does the clutch closing coil is defective and you will need a set of compressor tools to replace it.
Jul 19, 2012 | 1997 Dodge Caravan
Im trying to replace the ac clutch on an 04 mustang. i have the clip off but the clutch won't slide off. help please
Clutch and Clutch Field Coil adobe.gif Printable View (235 KB)
Special Tool(s) st1260a.jpg 2-Jaw Puller
205-D026 (D80L-1002-L) or equivalent st1232a.jpg Installer, A/C Compressor Coil
412-065 (T89P-19623-EH) st1235a.jpg Holding Fixture, Compressor Clutch (3.8L vehicles)
412-098 (T94P-19703-AH) st2584a.jpg Holding Fixture, Compressor Clutch (4.6L vehicles)
412-103 (T95L-19703-AH) st1220a.jpg Remover, Differential Bearing
205-116 (T77F-4220-B1) st1234a.jpg Installer, A/C Compressor Field Coil
412-078 (T91L-19623-CH) st1233a.jpg Remover, A/C Compressor Field Coil
412-067 (T89P-19623-FH) Removal
  1. Remove the A/C compressor (19703). For additional information, refer to Air Conditioning (A/C) Compressor - 3.8L or Air Conditioning (A/C) Compressor - 4.6L in this section.
  1. Remove the bolt.
    1. Hold the A/C disc and hub assembly (19D786) with the special tool.
    1. Remove the bolt.
  1. Remove the A/C disc and hub assembly and the A/C clutch hub spacer (19D648).
    1. Thread an 8 x 1.25 mm bolt into the A/C clutch to force it from the compressor shaft.
    1. Lift the A/C disc and hub assembly and the A/C clutch hub spacer from the compressor shaft.
  1. Remove the pulley snap ring.
  1. Remove the A/C clutch pulley (2E884).
  1. ani_caut.gif CAUTION: Do not use air tools. The A/C clutch field coil (19D798) can be easily damaged.
    Remove the A/C clutch field coil.
    1. Note the location of the A/C clutch field coil electrical connector.
    1. Install the special tool on the nose opening of the A/C compressor.
    1. Install the special tool.
    1. Remove the A/C clutch field coil.
Installation
  1. NOTE: If installing a new A/C compressor, the A/C clutch components should be reused unless obvious signs of damage are found. If excessive grooving is found, a new A/C clutch disc and hub and A/C compressor pulley must be installed together. Otherwise, each component can be installed individually where needed.
    Visually inspect the A/C clutch disc and hub, A/C compressor pulley and A/C clutch field coil for damage.
    • Inspect for physical damage, including cracked or melted components or discoloration due to excessive heat.
    • Inspect for excessive wear, including grooving in the A/C clutch disc and hub or A/C compressor pulley that is more than fingernail depth.
    • Inspect for roughness in the A/C compressor pulley bearing.
  1. Clean the A/C disc and field coil and pulley mounting surfaces.
  1. ani_caut.gif CAUTION: Do not use air tools. The A/C clutch field coil can be easily damaged.
    Install the A/C clutch field coil.
    1. Place the A/C clutch field coil on the A/C compressor with the A/C clutch field coil electrical connector correctly positioned.
    1. Using the special tools, install the A/C field coil.
  1. NOTE: The A/C clutch pulley is a tight fit on the A/C compressor head. It must be correctly aligned during installation.
    Install the A/C clutch pulley.
  1. Install the pulley snap ring with the bevel side out.
  1. Place one nominal thickness A/C clutch hub spacer inside the clutch hub spline opening.
  1. Install the A/C clutch.
  1. Using the special tool, install the A/C disc and hub assembly retaining bolt.
  1. Measure and adjust the clutch air gap by removing or adding A/C clutch hub spacers.
  1. Install the A/C compressor. For additional information, refer to Air Conditioning (A/C) Compressor - 3.8L or Air Conditioning (A/C) Compressor - 4.6L in this section.
hope this helps
Aug 13, 2011 | 2004 Ford Mustang
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
