Question about Sharp Microwave Ovens
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
    Scholar:
  • 178 Answers
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Posted on Sep 13, 2009
  • David Hanks Sep 13, 2009
    It's also possible that the door sensing switch (top one) has become loose in it's cradle on the door hook and is not actuating when the door is closed. Be sure to check this closely.... it's easy to miss....
My Sharp R-1460 microwave will not shut off when I close the door
This is odd. Normally it would only run with door closed? Is that what you mean?
There is a door interlock switch that should stop the oven if the door is opened.
THIS IS A DANGEROUS ITEM IF IT OPERATES with the door open.
Mar 27, 2017 | Sharp Microwave Ovens
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Microwave does not heat.....will not shut off power unless unplugged...
Check the door switches or moisture on the control panel.
Hope that helps.
Jan 16, 2011 | Sharp R-1460 Microwave Oven
My Sharp R-1460 Microwave Oven blanked out on me. I replaced the fuse and all lit up. When I went to turn it on to run, it blanked out again. Can you direct me to what the priblem might be?
I suggest the door switches are probbaly faulty. A job to say which one but you may find that it is caused by contamination or condensation.
Hope this helps.
Oct 28, 2010 | Sharp R-1460 Microwave Oven
Our oven started coming on when the door was shut. It is not cooking but the light and the fan come on. Nothing makes it stop except opening the door. I unplugged it for awhile, but that didn't help...
I have the same problem.
I found that by removing the control panel, then moving the small red-buttoned switches around the door open switch seemed to solve the problem.
We felt the problem was a mechanical problem because closing the door very gently permitted normal operation.
Sep 24, 2009 | Sharp R-1460 Microwave Oven
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Microwave is dead. wont lite up. Power source is fine.
We have a similar situation where we were heating food, there is no power. The model #JVM1090 Serial # 912305S. Is there a fuse or reset button, we do have the owner's manual and would like to make the repair if it is simple.
Thank you for your help
Joe Spano
Nov 25, 2008 | GE Microwave Ovens
Microwave automatically comes "on" when door is closed, but no heat.
I have the R-1460 in the same series with the identical symptoms. After reading MicrowaveSvc's solution I started taking apart to view the door switches and found the upper door switch to be the problem, but not a switch failure a support failure. A small bottom plastic support post that holds the switch in place was broken (probably from repeated use/abuse) allowing the switch to move when the door hooks were engaged, thus not actuating the button switch. Since the problem was mechanical rather than an electrical bad switch, I made a small support arm for the switch from an old plastic mechanical pencil and glued it in place to hold the switch in its correct position. Problem solved, microwave works! Thanks to MicrowaveSvc's description of door switches.
Mar 14, 2007 | Sharp R-1460 Microwave Oven
Over the range microwave
Sounds like you have a shorted triac device inside the microwave. Very common problem. This is not a replaceable item for the user to replace.Looking at the age and the make of this microwave,it way be time to purchace a new oven ? Good Luck
Aug 08, 2006 | Sharp R-1460 Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
