Question about Garmin Nuvi 760 Handheld GPS Receiver
The GPS operates for a few hours than turns off and cannot be turned on again until the next day.
  • 525 Answers
Check for power connector or adapter
Posted on Sep 13, 2009
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
How do you set for 7 days lights on and off
Intermatic has two slightly different ways depending on model. first way:
Press MODE until the screen displays PGM
with blanks for time.
Press DAY/DST as many times as necessary to
display 12:00 a.m. and the day(s) you want
the program to activate. Choices are:
- everyday
- weekdays only
- weekends only
- a specific day
NOTE: If you go too far, keep pressing DAY/DST to loop back
around again.
Press HOUR+ to set the hour you want the program to turn ON.
Press M+ to set the minutes you want the
program to turn ON.
Press NEXT ON/OFF to set the OFF time for the
program. The screen again displays blanks.
NOTE: Since you're setting an OFF time for an
ON event already programmed, choose the
same days as in the ON event.
OFF.
program to turn OFF.
At this point you have two choices:
Press MODE if you are finished to exit from programming.
Press NEXT ON/OFF to set another program. Repeat from
Step 2 above.
Second way:
Press the MODE button one time. (PGM) will be displayed on the top left corner of the timer. We are setting the ON time for Program 1. --:-- -- 1 ON will be displayed on the screen.
Press the DAY/DST (bottom left) button to select the day or series of days the timer is to turn ON. You can either select the ASTRO time, which will adjust as the days get longer and shorter or a specific time. To use the ASTRO time press the DAY/DST until SNST appears on the screen. All seven days will be shown on the bottom of the timer.
Or to use a specific time press the DAY/DST button and select the day or series of days the timer is to turn ON.
Use the HOUR+YEAR- (bottom center) button and select the HOUR to turn the unit ON. Use the
M+ZONE+YEAR+ (bottom right) button to set the MINUTES of your on time.
Press the next ON/OFF button one time. We are now setting the OFF time for program 1. Press the DAY/DST (bottom left) to select the day or series of days of operation. To use the ASTRO time press the button until SNUP appears on your screen.
Or to select a specific time, press the DAY/DST button and select a day or series of days the unit is to turn Off.
Press the HOUR+YEAR- (bottom center) button and set the hour of your off time. Press the M+ZONE+YEAR+ (bottom right) button to select the minutes of your Off time.
For additional programs press the NEXT ON/OFF button to the next program and follow above steps. Check the unused programs to assure they are blank. To check the other programs press the NEXT ON/OFF button, you should see --:-- -- on the screen. If a time appears press and release the DAY/DST button until the --:-- -- appears. Repeat this step thru Program 7 off.
Press the MODE button. (AUTO) will appear on top center of screen.
If you cannot program, try to reset the whole timer:
Press the RESET and the NEXT ON/OFF buttons at the same time. Release the buttons and wait for 1200 to start blinking.
Nov 07, 2010 | Intermatic & Self-Adjusting Wall Switch...
GPS (2008 Denali) stops working after 1+ hour of driving.
drive the auto for 1 hour then take it to the dealer and have them check it out do not turn off the vehicle when you arrive leave someone in side until they can service you sittuation
Apr 01, 2010 | 2008 GMC Yukon Xl 4WD
Initial setup to operate gps?
you normally wouldnt have to but it is recommended to charge it. if it was tested before it was packaged, its possible it was in sleep mode instead of turned off..if its in sleep mode, it will drain the batteries over time. if its not starting, charge it for a few hours, then hold the power button untill it starts. if that does not work, try a hard reset.
Jul 09, 2009 | Magellan Maestro 4250 GPS
Turning on
You may need to keep it plugged in and charged for a few hours before you turn it on again. I ran into a similar issue where there was no juice left in the battery, but after doing a full charge, it worked fine.
Jan 14, 2009 | Tomtom XL 330 Car GPS Receiver
Zenith P60W26P beeps and won't turn on until next day.
I am having the same problem, beeping and will not come on until the next day....did you find a solution?
Jan 06, 2009 | Zenith P60W26 60 in. HD-Ready Plasma...
Recently after working one day the next day when i tried to use mt tom tom 710 it wouldnt switch on but the mains light was lit when plugged into cig lighter
Try giving it a full charge. I used different model Tom Tom that would not turn on even if plugged in until after the battery was recharged.
Oct 10, 2008 | Tomtom GO 700 GPS Receiver
Help solve my problem
Have you tried charging the unit on the computer? If not, try this for a few hours. Sometimes this can help.
Oct 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
