I have a magnavox tv and I'm missing the remote so I can't access menu to remove closed caption.
  • 525 Answers
Go to the store and buy a universal remote control.
Posted on Sep 13, 2009
How do I shut off the captioned dialogue on the screen for my magnavox smart series tv. there seems to be no such choice on the menu
hi,
For closing the Closed Caption option do the following.
1. Press the MENU button on the remote to see the menu.
2.Press the up arrow or down arrow until the CC (Close Caption) is highlighted.
3. Press the right arrow repeatedly until CC OFF appears.
4 .Press the menu button to exit.
Or, you also can set Closed Captions by pressing the CC button on the remote. Press CC repeatedly to select: CC-OFF,
ok
Feb 07, 2011 | Philips Magnavox 20MS233S 20" TV
How do i remove closed caption on tv - can't get menu option on remote to work - thanks.
What is the TV source? Could the captions be coming from that source? If it is, try disabling them from the Menu for the set top box (cable, satellite, DVD).
There is a menu button on the TV that will let you access the OSD if the Child Lock is not enabled.. Then the same directions apply Set > Closed Caption (Off, CC-1, CC-2, CC-Mute). If you can't access the menu directly, then the control board may be bad. Try shopjimmy.com for used parts with minimal wear (sets that were broken in shipping) or another supplier. You will need to open the TV and get the part number of the current board.
I hope this helps.
(the set-top box issue is one I have dealt with. A neighbor with an older TV needed to use the captions from the satellite receiver set to single mode to get captions for the visiting relative. This meant that both sets watched the captions until they were turned off. The main TV still showed the captions if they remembered to reset the receiver to Dual mode.)
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
Lost remote, somehow child turned on closed caption without remote,how do I disable closed caption without remote?
Find a button on the tv manual control said Menu,press it. Goto tv menu find and turn off all CC1,2,3 and text 1,2,3.U should have no more closed caption.
Sep 12, 2010 | Philips Magnavox 20MS233S 20" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
How to remove closed captioning on tv screen
Press the Caption button on the remote control to cycle through the caption options until OFF appears. If there is no Caption button on the remote, go to the system menu and turn captions off in the caption submenu.
Jan 08, 2010 | Philips Magnavox 20MT133S 20" TV
I cannot get closed captioning to turn off and stay off on my magnavox tv. the menu has no cc options at all. and the remote turning it off is onl,y temporary. any ideas?
I have the same problem, but I cant even get a code for my universal remote to access my menu or any of the settings. Dont think I will buy Philips/magnavox any more.
Oct 19, 2009 | Philips Magnavox 20MS233S 20" TV
I need help with removing captions
This information was found on the Magnavox website http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602222010_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals in the owners manual on page 20. If this information does not solve your problem. Try calling Magnavox customer support at this telephone number 1-800-705-2000. Give them the model number of your television and tell them about the problem you are having with not being able to turn of the closed caption feature. I hope this helps you solve your problem. 1Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL- to display the
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE). CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL- to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Apr 23, 2009 | Philips Magnavox 27MS343S 27" TV
How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Mar 19, 2009 | JVC C-20810 TV
No remote to turn off Closed Captioning
if your tv has a menu button on it enter and try ot turn it off via thr front control buttons
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
to display the
CC-2, or CC-MUTE).
CC-MUTE sets
restore the sound.
to confirm your
selection.
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
