Question about Brother HL 1440 Laser Printer
I have the similar problem
The print out always has vertical line.
    Scholar:
  • 136 Answers
Replace Drum see if this Solves Problem
if not Defective Fuser
Posted on Sep 13, 2009
Why am I getting yellow vertical lines on my printing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to some popular brand printers are given with illustrations.
Aug 09, 2014 | Ricoh Aficio SP C811DN-DL Printer
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
I have vertical lines that are missing the black toner on everything i print, the lines are always in the same place so i assume it has something to do with the transfer of black toner in those spots. the...
If your printer prints with faded bands similar to this:slamfix_29.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Jan 24, 2011 | Samsung CLX 3160fn All-In-One Printer
Vertical blank "line" on printed material.
try the toner cartridge. You can see where its coming from by printing 1 page. When the page starts coming out of the machine open the cover. Take out the toner cartridge and look at the page. The line should be there and you should be able to figure whats causing it. It's almost always the toner cartridge. If you have an old cartridge put it in and run a test with it. If the line is gone its the cartridge. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 1100 Printer
Hp 2605dn printer has a vertical line on all print outputs
Lines verticle or not are almost always coming from the cartridge. Replace the toner cartridge and check print quality. If you do not have a spare, remove the toner cartridge. Flip it over and slide open the drum protection plate. Look to see if a similar "line" is on the drum surface. If it is then that is your proof that the problem is in your toner cartridge.
Dec 14, 2009 | Office Equipment & Supplies
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
HP 2600n prints some blue vertical lines
1 of 2 things: First, check yuor Cyan cartridge and make sure that it is not leaking. It may have a bad seal. If you replace it with a known good toner, the imaging unit (the black acetate thing) will need to be replaced. This is also a consumable unit.
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Brother HL 1440 Laser Printer Logo
50 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
