Question about Honeywell Programmable Thermostat Heater
Thermostat will not let us program the cooling past 72 we have tried to move the temporary setting also useing the hold temp button and pushing the decrease key, it seem to be locked at 72
  • 55 Answers
You need to get into the installer settings to lower the minimum setpoint. look up your model online and try that. Otherwise you may have an older style auto changeover type t sat in which case you should still look up the manual and reprogram from the installer configs. or try buying a new one
Posted on Sep 13, 2009
Why does my Honeywell thermostat state temporarily set at 68 degrees? A few days later, it will be set at 62 degrees without anyone touching the thermostat?
It's a programmable thermostat. When you change the temperature, it will say temporary until the next programmed schedule starts or a set amount of time. You will have to program the thermostat to the correct temp settings you wish to have, or you can push "HOLD" after changing the temp to make it stay at that set point. Hope this helps!
Nov 19, 2016 | Heating & Cooling
Thermostat does not reach programmed temperature
Have you checked with a thermometer to see if the area is reaching the temp you have it set at? A thermostat has nothing to do with the temp in your house. If you have it set at a temp for Example ( 72 ) and it is not reaching that temp to shut off then you have a problem with your unit or insulation in house. If you set stat on cool at 72 and the house gets down lower than 72 then there is a problem with stat.
Dec 19, 2014 | Honeywell CT500 Digital Heat / Cool Manual...
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
What does temporarry and hold mean on thermostat
Sounds like you have a programable thermostat. the temporary setting is when you change the temp setting to a different temp and it will stay at that setting until the next programed change. The hold setting is to hold the temp setting you have chosen for an indefinate time. It overrides your programed settings.
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
Why is it displaying "temporary"?
The automatic programming has been overridden to, for example, increase the heat temporarily until the thermostat is returned to automatic operation.
Jul 03, 2012 | Honeywell Electronic Programmable...
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
How do I set my thermostat for my furnace? My thermostat wont come on appropriately. I think I pushed wrong buttons and can't get the heat to stay on. Would like to cancel settings and be able to set...
Set the System switch to either Heat or Cool. Press the Hold Temp button. Use the Warmer/Cooler buttons to set temperature. Temps will stay until you either turn off the system switch or press Run Program.  Good luck.
Jan 02, 2010 | Honeywell CT3200 5-2 Day Electronic...
I set the tstat manualy for 77 and when we wake up it reads83 what? thanks
You have a pre-programmed thermostat. You'll need to put in settings for each program setting in order to have the thermostat provide you with the heating/cooling temperatures you want at each time period of the day and for each day of the week (in the case of a 7 day programmable model.
Whenever you put in a manual temperature setting, it is only a temporary setting that will get reset at the next pre-programmed temp setting, unless you set the "HOLD TEMP" setting and select the number of days you want it to hold the temp you manually set on the T-stat.
If you can provide the model number, I can help you further with the programming of your T-stat.
Hope this helps and best regards!
Thanks.
Aug 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
141 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
