Question about Kicker KX600.1 Car Audio Amplifier
Car audio i have connected two amplifiers one multi channel and one mono it worked fine but now the multi channel cuts out what could be causing this problem
  • 376 Answers
Low grade patch cables, or connection secquence incorrect, monoblock amps require a heavy input load, it should be the last one in config-
the mono will pull alot of amps from the source pos. thus ripping off the other amps in lineuse good patch cables to feed the multi first, then the mono....
Posted on Sep 13, 2009
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
Can this amp be bridged mono?
Yes, connect the speakers to the red terminals only for bridge, you good to go.
Nov 28, 2013 | PS Audio GCA-250 2-Channel Amplifier
How to hook up two amp,one a four channel Directed 1000watta and the other a mono Directed 2400wattD.
gonna need 6 pre out connections front and rear for the 4 channel and a sub out for the mono.i would also recomend a 1farad capacitor for that
Sep 12, 2010 | Directed 2400d Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
Retry.
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Dec 21, 2008 | Performance Teknique ICBM-Digital Car...
Connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
May 25, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Is it not bridgable
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Alpine PDX-4.100 3ch operation
use channel 1 and 2 as normal, use the positive from channel 3 and the negative for channel 4 as mono 1ch, your bridged output on the mono chan should be around 200watts at 4ohms.
Nov 25, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Kicker KX600.1 Car Audio Amplifier Logo
59 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
