Question about Sprint Palm Centro Smartphone
Keys on my palm centro won't work!
My touch screen works so I can still make calls, but none of the navigation keys will work. I can't even press the end button when I want to hang up a call, and I can't use the keypad to . Had this phone for only a little over a year, any way it can be fixed or should I just find a new phone?
I have the exact same problem and dont seem to find any answer on how to solve it in any guide. Were you able to sort out this problem? If so, please share!!!
Posted on Jan 17, 2010
None of my navigation keys work on my palm centro  only the touch screen works on my phone
Posted on Oct 07, 2009
    Problem Solver:
  • 10 Answers
Some phones have a keypad lock so you dont accidentally hit the buttons if its in your pocket or something. Maybe try to go to settings and see if there is anything like that.
Posted on Sep 13, 2009
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
My palm centro keyboard and other buttons randomly stopped workig
Hello hyuuga4567,
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option +
Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Sprint Palm Centro Smartphone
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
• Select Prefs
• Select Keyguard.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
CANT USE ANY BUTTONS ONLY TOUCH SCREEN
it is toast, yes dropping does it, so does camping, (moisture). if you got the insurance then you are ok just go replace it cheap, and pray tht you can get your data on the new one.
Aug 18, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Same problem as red light /hot sync issue phone dead.
well, this same problem happened to my phone after it got a bit wet. I think you should leave ur battery out for at least two hours, and then put it back in. it will turn on, and charge it im not sure if itll work for sure but my touch screen works fine and my keys work on and off but it still turns on and can be functional.
Jun 22, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
New touchscreen does not work.
Pls first hard reset ur phone like this if it doesnt help then go to AT&T it is a possible Touch Panel Failure they will do it Free if u are aunder warranty i think u are
but pls try first RESET here
http://kb.palm.com/wps/portal/kb/na/centro/centro/att/solutions/article/887_en.html#hard
and also see this for New user info
http://kb.palm.com/wps/portal/kb/na/centro/centro/att/solutions/article/45008_en.html
May 08, 2009 | AT&T Palm Centro Cell Phone - White
Palm centro wont boot
Do a reset. You will lose all items on you device.
Take battery out. Put it in and hold the power button on till you see the palm logo the second time. Release when you see the 2nd logo. It will prompt you for pressing up to delete and reset. Press Up. It will take some time to reset and reformat but please wait.
After that your phone should come to the setup screen. I would hotsync after you setup to get your contacts  back.
Apr 25, 2009 | Palm Treo 500 Centro
The internal speaker on my Palm Centro does not work. Speaker has been tested on other Centros and is working fine. External speaker is working ok. What could be the problem?
your microswitch is stuck. swab your earphone jack with light oil and insert in and out and around. This has work for me and others
Apr 01, 2009 | Sprint Palm Centro Smartphone
Palm Centro hearing
I hate to sound obvious but have you checked the volume setting? Took me a few days to realize they were there - I almost never read the manual. :) The two volume keys are on the left of the phone as you look at the screen. Hope this helps.
Oct 24, 2008 | Palm Treo 500 Centro
Sprint Palm Centro Smartphone Logo
862 people viewed this question
Top Sprint Computers & Internet Experts
Computer Repairing
Computer Repairing
matt
matt
Are you a Sprint Computer and Internet Expert? Answer questions, earn points and help others
