Question about Dell Dimension 4500 PC Desktop
Dell Dimension 4500 has been working fine but won't start now. No fan, no power when press power switch. Have taken front panel off, and switch seems okay. How to check power supply?
  • 428 Answers
The problem with your Dell Dimension 4500 is that its power pack (the device that supplies power to the mother board) is bad. The only solution is to replace it (Though sometimes it could be fixed, my recommendation is get a new one, the price to fix and getting a new one are about the same anyway). To do this you need technical support unless you are a technical person. The fact is it is a very simple procedure. But to be sure that nothing goes wrong or another complication doesn’t arise you need a technical person to change the power pack. However, if you a technical person and you are sure this your comfort zone, follow this procedure:-
Open up the CPU casing. Unscrew the power pack (this is the device you plug in your power cable from the back of the CPU). Take it to any computer accessories store and purchase one with the exact power specifications. Return it to your CPU, screw it back and plug in to your board and devices.
Power on the System.
Posted on Sep 13, 2009
    Sergeant:
  • 166 Answers
There is a power supply problem. change the power supply.
Dont forget to vote fixya rating
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
My dell desktop won't start. when press the front panel button, computer won't start
check the power connections, if its okay change the power supply or smps
Jul 27, 2011 | Dell Dimension 3100 PC Desktop
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
Amber light on start button of Dell Dimension 4500
This is one of three things.
1. Bad Power Supply - Check to see if the fan is spinning
2. Short in the the wiring or Bad piece of Hardware - Check wiring make sure none of it is damaged. Disconnect one component at a time and try powering the PC on.
3.Badmother
Try steps 1 and 2 and if those do not work it is a bad motherboard.
This from a Dell certified Technician.
Oct 16, 2009 | Dell Computers & Internet
Without tools or other spare components/computers, how to troubleshoot ''dead'' Dell Dimension 4500? No beeps/fan, etc. Have taken off front cover and switch seems okay mechanically. Small green light on...
With case open, and power ON...
locate the two "power" pins that were connected to the power button cable that is on the front cover.
Find them and tempoarily "short" them with a metal thingy, like a paperclip, taking care not to touch any other components. If it starts or produces a beeping code, then put it all back together and make sure the power pins are properly connected.
If it doesn't work, then perhaps the 12 volt side of the power supply is out. The mobo LED is powered by the 5 volt side of the PS.
The 12 Volt side powers heavy things, like the hard drive motor, fans, cd drives, etc.
the 5 volt side if for the data bus or circuits.
The power supply may have several "legs" of cables. If so, use only one set to see if the system works; then the other.
I hope this helps and it works!
Sep 13, 2009 | Computers & Internet
Dell Dimension 8400 Start up Fan Noise
Might be a hard drive issue. I had the same problem with one of My desktops. I replaced the hard drive and it worked fine.
Jul 01, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Dell Dimension 4500
connect this cable to socket, which is in left right corner of motherboard (its on the left side of the bottom pci)
Feb 26, 2008 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500 PC Desktop Logo
228 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
