Question about Western Digital Caviar (wd800lb) 80 GB Hard Drive
Boot up problem
What does WDC WD800LB-55DNA0 mean?
Not installed windows xp for fatel error
Posted on Dec 11, 2007
Primary master wdc
Primary Master .
This is where the hard disk parameters are entered for the primary master IDE/ATA device, the first drive in a modern IDE system. See the hard disk section for details on what these terms mean and how these devices are set up. The various settings for the drive are discussed in detail in the IDE Setup / Autodetection section. The default setting for this on a system with IDE autodetection, is usually "Auto"
WDC That Mean Western Digital Company.This's Logo HDD.
First Time If you have Problem With Bios You can Select Load Default Bios to clear any fault setting before.and select Save&exit.
To verify problem again.
Jun 22, 2015 | Computers & Internet
My computer t-40 laptop starts to boot but then shows pxe-e61 media cable disconected pxe-mof intel boot agent,I bought this laptop used ,I was told that it was tring to boot from a net instead of...
Hi there, please try this trobuleshooting steps. after you push the power button quickly tap the F12 key until you reached too boot options menu. once you are already at the menu, select you Hard drive usually harddrive represent as model e.g WDC **** it means western digital. once you slected the harddrive your computer should boot now to your Harddrive. if else fails, waht you need now is to check if you cmputer was able to detect you harddrive. restart the computer then this time keep tapping the F1 key to enter the utility setup. once inside the setup check your system information under internal HDD if motherboard can detect your harddrive. if yes, then all you need to do there is to use the recovery cd that came with the system then boot your computer from the cd rom then install you windows. If not, then you have to contct your manufacturer. that could be a defective harddrive. please let me know if you need more help.
thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 07, 2010 | IBM ThinkPad T40 2373 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Try resetting the BIOS to the default settings and reboot
Nov 28, 2009 | Compaq Armada E500 Notebook
I have an Acer AOA 150 can't boot from usb
some bios setup don't have usb boot setting.pls check your bios first if there is USB enable.
May 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Its saying failure predicted on hard disk 2:wdc wd2500bevs-22usto i cant get on the internet or use the computer cant do anything
Seems like your hard drive is about to die.
To double check, install http://support.wdc.com/product/download.asp?groupid=702&sid=30&lang=en
Burn the iso to a cd. Make sure you burn it as an image file.
Then when you turn on the computer, enter bios and make sure boot from cd is selected first. Restart with the cd you made inserted.
Let the tests run. If it fails a test, then contact westerndigital for a replacement. Tell them it failed the diagnostic tests.
Aug 12, 2008 | Gateway Computers & Internet
Old hard drive
just plug the old hard drive into your new system insuring that the setting of the jumpers on the old harddrive are set to slave. then when you boot up your system your operating sustem will detect the old harddrive and then you can access if in the my computer folder. In order to keep the the operating system working in the old harddrive do not delete any system files just delete the data you copied in to the harddrive, to be safe do not delete anything in the windows folder in the old harddrive
Jul 03, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Drive has power but fails to come on
hi if try bios setting then setup it..
Open your hdd Drive change your jumper .....restart your pc put in Any OS Xp Driver...press ok enter 5 times if it boot then format & setup it....
Jun 29, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Western Digital Caviar (wd800lb) 80 GB Hard Drive Logo
96 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
