Question about Maytag PAV2300 Top Load Washer
Maytag PAV2300 - Washer agitates during wash. on spin cycle motor runs and belt is fine, but drun does not spin. Water drains. Why does it not spin?
    President:
  • 1,136 Answers
Hi, The most common problem is the thrust bearing kit. The thrust bearing is located on the lower shaft of the transmission. The kit includes a new pulley and hardware. The part #12002213 also includes instructions.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Sep 13, 2009
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
It does not agitate when in the normal cycle and does not drain.
"Does not agitate" sounds like a broken or worn drive belt. "Does not drain" sounds like a broken or worn pump belt. Since it is unlikely that both belts are bad, I suspect that the next common link, the drive motor, is bad, i.e. your drive motor is either defective or not getting power during the agitate and spin cycles. The primary symptom for a non-operating drive motor should be obvious, i.e., the machine just doesn't run after the wash fill, and it doesn't empty when the timer advances to the spin/drain cycle. If the drive motor does sound like its running, I would then inspect both belts and drive motor pulley for proper operation.
Oct 04, 2009 | Maytag Dependable Clean Top Load Washer,...
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Machine does not agitate, will spin and rinse including.
Yes, transmission. this is under ten year manuf. warr.
Feb 01, 2009 | Maytag PAV2300 Top Load Washer
WASHER WON'T WASH
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
Jan 31, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 AWW nevre agitates and only spins once.
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Oct 26, 2007 | Whirlpool LTE5243D Top Load Stacked...
Maytag PAV2300 Top Load Washer Logo
354 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
