Question about Nokia 6110 Navigator Cell Phone
Phone is set to working off-line - how do I change it?
  • 421 Answers
Sir reset your phone reseting code *#7780# put these code on your phone keypad then phone will ask you to reset yes or no click yes phone will ask you for your security code put 12345 then click on contiue phone will restart and settings will be restored and will be online mode
Posted on Sep 13, 2009
Display shows line in use after installing batteries but phone is not plugged into wall
Phones show "in use" when the line voltage is low because another set is off-hook, which also happens when the line is unplugged. In other words, that is normal.
What happens when you do plug in the line? If it still shows in use then, the jack might be wired with reversed polarity. Try it elsewhere - someone else's house/office where the phones work "normally" to see what it does.
Feb 11, 2015 | AT&T ATT Speakerphone CL2909
I can change Line2 to line1 in my phone there in no out going n my mobile how to change line 2 to line 1
To change from lines between line 1 and line 2 follow the steps below,
Press menu > Settings > Calls or Line 1 or Line 2 for dual line
phones then press the Change key to change it.
Thank You
Aug 12, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Changing phone line from line 2 to line 1.. motorola L7
In your handset go to Main menu >> Settings >> Phone status >> Active Line >> Line 1.
OR (If it not helpfull)
Main Menu >> Settings >> in Call Setup >> My caller ID >> All Calls >> Show ID.
May 20, 2009 | Motorola Mobility SLVR L7 Cellular Phone
M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Mar 04, 2009 | NorStar Meridian M7310 Phone
Fax doesn't recognize incoming phone call
Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
Answering call
Feature ** 266344 password 266344 (assuming the default passwords are set)
A. Configuration
2. Line Access
Show set (enter the telephone extension set number that needs to be changed) ex 34
Then press enter 4 times until you see the 'Prime Line'
Press the change button to set the desired line that will activate when the handset is picked up.
(It will probably display 'None' at present before change)
Press enter and release.
Aug 19, 2008 | NorStar M7310 Corded Phone
Fax network not working
Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
Jul 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
No link to base
The solution works!
Thanks.
Feb 15, 2008 | Panasonic KXTG2344 Cordless Phone
M7310
go and edit ur phone settings..its not ur fault it is by the operator..just contact ur gsm operator at call cantre and edit all the settings as he guides u........
Dec 04, 2007 | NorStar M7310 Corded Phone
Nokia 6110 Navigator Cell Phone Logo
138 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
